Spraying to cut lag?
Old Oct 12, 2003
RiceBuRNeR's Avatar
Turbo Member
I know that some other members are spraying on there turbo'd civics. So I was thinking about buying a NX wet kit and jetting it for about 20-25HP. Think that would be safe w/ a max boost of 10 psi?. Im hoping I can use the n2o to eliminate some of my turbo lag.
Old Oct 12, 2003
Jodster's Avatar
Post Whore General
I don't know about 10 psi. Do you have any internal work? If not I wouldn't recommend going over 6 psi with spraying.
Old Oct 12, 2003
RiceBuRNeR's Avatar
Turbo Member
No internals, but Im not going to use it during full boost. I just want to use it to get the turbo spooling quicker.
Old Oct 12, 2003
blckpwdr's Avatar
blckpwdr is an unknown quantity at this point
i'm running 9 psi and I have the 35 shot jets to cool the intake charge.
Old Oct 12, 2003
RiceBuRNeR's Avatar
Turbo Member
Awesome, you have the TD kit too right? So does the spray help reduce lag?
Old Oct 13, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
imo... nitrous plus boost = BOOM in non-built bottom end... seen it too many times... what kinda turbos are you guys runnnin that you need to spool faster? mine spools REEEEEEEEALLY fast.,..........
Old Oct 13, 2003
blckpwdr's Avatar
a smaller shot like a 35 shot helps cool the intake charge. it's not necessarily to help spool faster. Our turbo's spool fast as well. You're not going to just blow up your motor. You just have to know what you are doing and you have to know how to use nitrous.
Old Oct 13, 2003
blckpwdr's Avatar
RiceBuRNeR,
which one of our o2 sensors is the front one and which one is the back one?
Old Oct 13, 2003
prototype's Avatar
x-factor
i think "nos" brand nitrous sells a spool kit....i think ots a 20 hp shot
Old Oct 13, 2003
BoostedCivicZex's Avatar
Proud Srt4 owner
i need some small nitrous jets like a 30 shot or smaller for a zex kit, tell me if you got any to sell. Gonna use it just to cool down the intake charge instead of what i used to do, for power LoL
Old Oct 13, 2003
RiceBuRNeR's Avatar
Turbo Member
RiceBuRNeR,
The first o2 sensor regulates the A/F ration...dont F*** w/ it. The second o2 is the one that you would hook an o2 sim up to.
Old Oct 13, 2003
blckpwdr's Avatar
no. I mean, do you know which one goes in the front and which one goes in the back. I think one is green and one is black. I don't know if its true or not but I heard that you're not suppose to switch them. We have mine out and someone moved them and I don't remember which one goes in the front or back.
Old Oct 13, 2003
RiceBuRNeR's Avatar
Turbo Member
ohh...sorry. I'v never noticed a difference between the 2. You might want to ask around the tech forum.
Old Oct 13, 2003
blckpwdr's Avatar
yeah I'm not sure if it matters or not. just something that I heard.
thanks anyway
Old Oct 14, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
i would not recommend spraying at a low rpm. The cylinder pressure would be extremely hard on your internals.
Old Oct 15, 2003
RiceBuRNeR's Avatar
Turbo Member
^ IM talking at above 3,000 rpms just so that I hit my max psi quicker.
Old Oct 15, 2003
andyman97's Avatar
Turbo Guru
If you know how to launch the car, you won't have turbo lag either way. All you need to do is build the boost pressure up before you launch and there won't be any lag.
SammySC
121
Apr 7, 2017 07:43 PM
Bruce2
Sep 27, 2015 08:45 PM
tropicola
Sep 25, 2015 07:02 PM
pilebuck13
Sep 21, 2015 10:45 PM
