ball bearing turbo good?
Old Oct 4, 2003
AznPhoenix's Avatar
AznPhoenix is an unknown quantity at this point
is a ball bearing turbo better than just a regular turbo? and how does say hks ball bearing turbos compare wit the turbos SF offers with there kit? the garret t3
Old Oct 4, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Re: ball bearing turbo good?
For the cost... worthless performance-wise on a street car. It helps spooling by a tiny amount, and that tiny amount is what you'd want on a race car. Not worth the $$ on this car. All IMO of course.
The Garrett T3 is more than adequate IMO.
Old Oct 4, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
ball bearings are a difference where the turbine connects. At the rotating point of the turbocharger, where there is friction from one part spinning, ball bearings are inserted, which lowers the friction, allowing higher boost levels, smoother operation, and faster spoolup. The SF turbo upgrade is not this though; it is the upgrade to the T3 Super 60, which is slightly larger. I agree with Boosted2k2 that it is completely unnecesary for a civic.
Old Oct 4, 2003
detoX's Avatar
detoX is an unknown quantity at this point
which is better a t3 or t3/t4? pros and cons would be nice..
Old Oct 4, 2003
jwalker87's Avatar
Bodacious Member
check out http://www.eiptuning.com/eip03webfol...ochargers.html THis website mainly specializes in VW parts, but their turbocharger descriptions are great. Like I said, the turbo in the SF kit is the t3, and if you get the $100 upgrade, that upgrades to a T3 Super 60. Essentially a t3/t4 is turbine section from the t3, and the compressor section from the t4 (to4e). This allows little turbo lag, but supports high compression.
Old Oct 5, 2003
detoX's Avatar
so a t3/t4 is better for our cars?
Old Oct 5, 2003
jwalker87's Avatar
Bodacious Member
it is able to support higher levels of horsepower, yes. But if you read the description, it says under the t3 that it is ideal for smaller displacement cars...I don't know what you thought Honda's were, but 1.7L is pretty damn small. A t3/t4 is better, but on our cars is unnecessary. Our engine blocks can only handle about 11psi of boost with alcohol injection, and a t3 can easily handle that much power.
Old Oct 5, 2003
detoX's Avatar
i just read C2i0v0i1c posted he gets full boost at 4500 rpm thats bad ryt? i think i read catalyst has full boost at around 3000 rpm and he has a t3..for those who has the t3 where does the power end..at what rpm? just to make sure the t3 is better for our cas ryt? thanks..
Old Oct 5, 2003
RiceBuRNeR's Avatar
Turbo Member
MY TD kit came w/ a T25 BB turbo. Another great thing is that B turbos can take more compressor surge then thrust bearing type turbos.
Old Oct 5, 2003
andyman97's Avatar
Turbo Guru
Well, on a t3/t4, the housing is larger. Makes for longer spool time. The t3 has a smaller housing and with the 60 compressor wheel, it makes for quick spool and power throughout the entire rpm range. In other words, the turbo spools to full boost around 3200 rpm and makes boost to redline. Its a very powerful turbo and I love the way it feels from when it picks up all the way to redline.
Old Oct 5, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
Old Oct 5, 2003
C2i0v0i1C's Avatar
SuperMODrizd
i wanted a 50trim but got a 54 trim bc of future agenda....i do wish that it spooled completely by 3500 but ill take what i got
GolNat
Suspension DIY
May 12, 2022 06:49 AM
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
