prep for nitrous?
Old Sep 29, 2003
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
what exactly needs to be done to my motor to make sure i wont blow it with nitrous? What do i need to do to make my motor as strong as possible? Also where can i get these parts? Thanks
Old Sep 30, 2003
EnProceso's Avatar
i dont think you really need anything for a 50shot, i would suggest some gauges to keep an eye on things.
Old Sep 30, 2003
Mr.Modify's Avatar
what he said^^^^^
Old Sep 30, 2003
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
I agree, but I would consider buying a fuel pressure regulator though so you can bump your fuel pressure up a little, I believe with that, it is also safe to go 75 shot occasionally on the track.
Old Sep 30, 2003
yeah but say i wanted to run a higher shot, i want to know the things to do to make the motor indestructible.
Old Sep 30, 2003
MadWheel's Avatar
Premium Boosted Member
pistons, rods, block guard will def help. get some arp studs for your head too.
Old Sep 30, 2003
sspem2's Avatar
em2
you mite want to get a flywheel and a clutch to. after a while your stock ones will give if you use it to much. if your just gonna use it just a few times a month i recommened a/f gauge, nitrous gauge and oil pressure or any other gauge and a flywheel and clutch. just to be safe.
Old Sep 30, 2003
where can i get this stuff for the best price? Thanks for everyones help
Old Oct 1, 2003
ImportRacer2123's Avatar
K20 Member
EBAY!
Old Oct 1, 2003
01WingsWestCivic's Avatar
7thgen Man-gina
01WingsWestCivic is an unknown quantity at this point
you dont NEED anything to run a 35 or even a 50 shot. you can bolt it on to your completely unmodified engine, i would get a nitrous gauge at the least and youll eventually have to replace the clutch
Old Oct 1, 2003
LiTtOaZn2nR's Avatar
LiTtOaZn2nR is an unknown quantity at this point
when's the best time to use nitro in a race? like what gear or can u use nitro anytime u want to?...I might consider nitro for my auto
Old Oct 2, 2003
i want to run higher than a 50 shot.
Old Oct 3, 2003
7thgen Man-gina
spray in 2, 3 and 4th gear. you can spray at the top of 1st, but WATCH THE REDLINE
ttamrekab
Sep 28, 2015 01:22 AM
Theshwartz35
Jul 18, 2015 10:49 PM
MN-02-CivicEx
Jun 13, 2015 08:32 AM
crowtoo
May 11, 2015 06:50 PM
supermex
Feb 1, 2002 09:05 AM
