Launch & spool up?
Old Sep 13, 2003
UnOrthodox9546's Avatar
UnOrthodox9546 is an unknown quantity at this point
Question Launch & spool up?
When racing on normal tires what rpms do you guys launch at w/ turbo? Also what rpm does the turbo start to spool up?
Old Sep 13, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I haven't launched, or even driven above 4000 rpm because my fuel system still isn't fine tuned yet. But mine starts spooling at 2500. That's on a T3/T04B though.
Old Sep 13, 2003
iamboo's Avatar
Retired - SoCal FI Mod
you would just pulse the throttle at the line so the turbo spools a lil... i wouldn't gun it tho, cause you'll lose traction really fast on street tires... buy some drag radials and rev it off the line... it'll spin a lil but it should hook just find before you're done with your 60'....
Old Sep 13, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
like boo said
Old Sep 13, 2003
Jodster's Avatar
Post Whore General
Yeah, with slicks you could rev the crap outta it and dump it. But with street tires it would be better to feather the clutch.
Old Sep 13, 2003
PdchasinR6's Avatar
PdchasinR6 is an unknown quantity at this point
with my SF kit and upgraded turbo i found that slipping the clutch at 3000-3500rpms and feathering the throttle would produce the best 60ft times for me on my tires. for any FWD car its hard to get off of the line good with a turbo unless your running slicks. what worked for me though may not work for you. only about 30-40% of the time i would be able to hit that perfect margin of throttle and clutch slippage to make me not burn the hell out of my tires. anything below 3000rpms my car would bog HORRIBLY! anything above 3500 would be a waste of even trying to move but it'd leave a nice cloud behind me. my suggestions would be to take the car to the track and have a trial and error day b/c mostly every car is different due to turbo setup/tires/and most importantly the driver. latr
Old Sep 13, 2003
Thx for all the help !
99BoostedSi
Sep 7, 2015 04:49 PM
Jul 12, 2015 11:54 AM
Supramk3
Jun 11, 2015 11:13 AM
