Another MORE than satisfied SF customer
Old Sep 8, 2003
  #31
opto_isolator's Avatar
Originally posted by OsOBooSTeD
12.05 psi? NICEEEEE.... GLAD TO SEE ITS ALL WORKING ! WOOO
Yeah -
Old Sep 8, 2003
  #32
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
12.05 psi.. we have 12's ladies and gentleman... im scared.. ill admit it.. i dont wanna rip it all out.. just got it in... props for havig ***** man.. but that doesnt make you smart.. i PRAY you have alccohol injection..
Old Sep 8, 2003
  #33
C2i0v0i1C's Avatar
SuperMODrizd
dont need to
Old Sep 8, 2003
  #34
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
He has a built engine...unlike you. He doesnt need alcohol injection to run 12 psi. Also his fuel setup is way more comprehensive allowing him to run greater amounts of boost without risking blowing his engine, unlike you.
Old Sep 8, 2003
  #35
zinkyroo's Avatar
cool beans
woops double post
Old Sep 8, 2003
  #36
andyman97's Avatar
Turbo Guru
Built engine or not, without something to either raise octae or retarcd the timing, it doesn't matter, you'll still have issues with detonation.
Old Sep 8, 2003
  #37
zinkyroo's Avatar
cool beans
I dont think he is having any problems with detonation. Im sure his tuner is ver good, and can make 12 psi work without raising the octane or having to retard the timing. I mean look at cataylyst he was running 11 psi daily, on their fuel system, which is an fmu and fuel pump, where as c201icivic is running 12 with a return line, with bigger injectors and the E-Manage(?)
Old Sep 8, 2003
  #38
C2i0v0i1C's Avatar
SuperMODrizd
the only thing holding me back is the stock rods, and if those happen break then i have crower rods waiting in my room to replace them. another reason that im not worried about ne thing is that my compression is considerably lower that what i think to be anyone on this site. my tuners are the shiz, someone who can take a car that they have never worked on before, they specialize in honda and acura, make a return put the emanage in which isnt even listed in the manual on what wire is what, build a fuel map and plug it in and have it near perfect the first time says alot to me. and by tuners i mean two, the other one is the owner of DYNAMIC AUTOSPORTS, eddie kim. the car runs perfect on 93 octane, and idles like its stock, and puts out no smoke at all.
now back to the topic of this post, im glad u are happy with ur kit.
Old Sep 8, 2003
  #39
andyman97's Avatar
Turbo Guru
Not sure about c201 but I know catalyst wasn't running that high of boost without alcohol.
EDIT: Ok, with lowered compression, that's a different story. You couldn't run that high of boost on stock internals without something to prevent detonation.
Old Sep 8, 2003
  #40
OsOBooSTeD's Avatar
OsOBaNNeD
Originally posted by C2i0v0i1c
the only thing holding me back is the stock rods, and if those happen break then i have crower rods waiting in my room to replace them. .
are you NUTS? just to let you KNOW.. if ur rods break.... hmmm u know what lemmie show u want happens to our engine..cause i broke a rod... eh.. RATHER THREW ONE.... and if u think that ur just gonnna break a rod and replace them ur soooo wrong.... ull be replacing the engne...
first picture is the broken rod to show u.. and second .. well u ll see..
Old Sep 8, 2003
  #41
OsOBooSTeD's Avatar
OsOBaNNeD
yea notice the rod was sitting in the oil pan... about busted threw that too..
Old Sep 8, 2003
  #42
OsOBooSTeD's Avatar
OsOBaNNeD
lol and one more to show u what it did to the insides...
Old Sep 8, 2003
  #43
i dont know of anyone CORRECTLY running the SF kit and having smoke out the back end.. atleast not that i know of.. i have none.. im still on 4-4.5 psi for now.. didnt get a chance to turn it up any cause i need to have my exhaust flange modified to fit up with the downpipe better... ( NOT NOT NOT SF 's fault... exhaiust was made to fit my kamikaze which was actually shorter than stock for some reason..)... took a Porsche 944 Turbo on freeway on way home today by 1.5-2 cars... and i started off slow... rpms were too low... he was TRYING to race for like 1 mile... my gurl wouldnt let me... finally she was like.. "take him out already"....:LMAO./.. she's a KEEPER!
Old Sep 9, 2003
  #44
C2i0v0i1C's Avatar
SuperMODrizd
and my old lx block that i have will work just fine if i put a hole in the block, slap the vtec head on it after i sleeve the lx block, put the new rods and pistons in it and put it back together.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
rallyeredem0
Nov 2, 2015 10:56 PM
carid
Sep 28, 2015 10:13 AM
General DIY
Sep 25, 2015 08:02 PM
Jrosa
Sep 14, 2015 08:24 PM
