blow off valve
Old Sep 5, 2003
blckpwdr's Avatar
blckpwdr is an unknown quantity at this point
Question blow off valve
How do you guys have your blow off valve set?
Can It affect performance?
Old Sep 5, 2003
C2i0v0i1C's Avatar
SuperMODrizd
what do u mean how do we have it set, do u mean where is it placed on the pipe and can that affect performance, i think placement only affects sound
Old Sep 5, 2003
blckpwdr's Avatar
no, the adjustment screw
Old Sep 5, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
no but if u set it wrong the turbo will get backspin.. i forget what its called.. but its pretty bad to do...ur supposed to set the BOV to the lowest seting and then move it up to the highest point until ur car doesnt bog... --- but thats just what i hear
Old Sep 5, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
^^^ called Compressor Surge. The pressure builds back up into the compressor instead of escaping through the BOV.
Old Sep 5, 2003
C2i0v0i1C's Avatar
SuperMODrizd
is ur car done and do u have it back
Old Sep 6, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
compressor surge can lead to compressor stall.... meaning that your turbo actually stops spinning. Meaning that when you shift, you have the spool up your turbo all over again. Also compressor surge is bad for your thrust bearings and turbine shaft in the turbo.
Compressor surge can be caused by having the BOV adjusted too tight. But by adjusting it too soft, you can leak air while under boost.
Also placement of the BOV will also effect the performance of the turbo. The closer to the throttlebody the BOV is, the better. Because since you close your throttlebody while shifting, the pressure has to be relieved. If the BOV is down near the intercooler, the air has to actually change directions to relieve the pressure. But if it is right next to the throttlybody, then the air is still traveling in the same direction.
Old Sep 6, 2003
C2i0v0i1C's Avatar
SuperMODrizd
thanks bc i wanted to know that info too
Old Sep 7, 2003
Catalyst's Avatar
no prob, im here to help everyone out. As well as relieve stress
Old Sep 9, 2003
Entropy's Avatar
Entropy is an unknown quantity at this point
isn't the blow-off valve internal in the SF Kit? like in the turbo itself?
Old Sep 9, 2003
SaiyanMatador's Avatar
SaiyanMatador is an unknown quantity at this point
ur thinking of the internal wastegate dood, and blow off valves are usually mounted close to the throttle body as u can get. when sf first came out with the kits i believe they were using internal wastegates, but i guess now u have the option of using an external wastegate, sounds good.
Old Sep 10, 2003
Boosted2k2's Avatar
yup
Old Sep 10, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
chutch
Old Sep 10, 2003
RiceBuRNeR's Avatar
Turbo Member
I read that some rally drivers keep their BOV's set to retain a few PSI in between shifts to reduce turbo, and there are no thrust bearings in the TD kit. Its a dual BB turbo.
mrohitredd
40
Sep 9, 2017 12:03 PM
mjdiaz89
Jun 21, 2016 09:26 PM
MrOldskool
Aug 18, 2015 09:58 AM
mcollins
Jul 24, 2015 07:37 PM
Civic65
Jul 19, 2015 10:13 AM
