a/f gauge
Old Sep 3, 2003
blckpwdr's Avatar
blckpwdr is an unknown quantity at this point
a/f gauge
has anyone with a turbo connected an a/f gauge and got it to read consist?
If so, what did you connect it to?
Old Sep 3, 2003
iamboo's Avatar
Retired - SoCal FI Mod
which turbo kit and fuel setup did you go with???
cause i have the sf kit and my a/f gauge is reading rich at boost and pretty much all over the place at idle and cruising speed...
Old Sep 3, 2003
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
connect it to the 1st O2 sensor, i believe the black wire
Old Sep 3, 2003
RiceBuRNeR's Avatar
Turbo Member
Mine does the sam as cats. Youl notice that the TD kit is a little lean from the factory, hopefully my settings helped you.
Old Sep 3, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
get the greddy a/f...autometer is just good for a light show.
Old Sep 3, 2003
blckpwdr's Avatar
Yeah, the settings helped alot. Thanks!
I got the td kit. I have the gauge connected to the
ecu, but I wasn't sure if it would be better to hook it up
to the o2 sens. directly, or if it would matter.
Old Sep 4, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
O2 sensor or ECU... it's all the same signal. I have mine at the ECU.
Old Sep 4, 2003
blckpwdr's Avatar
boosted2k2,
does your gauge read consistantly or is it all over the place?
Old Sep 4, 2003
MadWheel's Avatar
Premium Boosted Member
It will bounce all over the place under normal driving conditions, will lean and usually not light at all under deceleration, and run rich under WOT.
Old Sep 4, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
not just for light show.. you just need to know how to read it! VERY purposefull
Old Sep 4, 2003
zinkyroo's Avatar
cool beans
Umm well its only sort of accurate at WOT. The Greddy one comes with its own 4 wire o2 sensor, so its a lot more accuarte and expensive
Old Sep 5, 2003
Boosted2k2's Avatar
yup
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
