Boost Question
Old Aug 26, 2003
UnOrthodox9546's Avatar
UnOrthodox9546 is an unknown quantity at this point
Question Boost Question
Lets say my brother is driving my car and i dont want it to be fast for him or for him to feel it fast, is it possible to turn the boost down to 0 or maybe 1 psi? If not whats the lowest you can turn it down to?
Old Aug 26, 2003
streetglower's Avatar
Do you have a boost controller? I am pretty sure if you have the boost controller you can turn up or down you boost. Just make sure it is hidden or he will see it and probably mess around with it.
Old Aug 26, 2003
Yea, i got a greddy profec b spec 2. But it is ok to turn it to 0 psi?
Old Aug 26, 2003
iamboo's Avatar
Retired - SoCal FI Mod
do you have an internal wastegate or an external ??
if it's internal, there should be like a default boost setting on it... mine was set to like 4-5 psi... this means that if you competely close off the boost controller i'm still running 4-5 pounds...
Old Aug 26, 2003
detoX's Avatar
detoX is an unknown quantity at this point
you can disconnect the actuator rod to run 0 psi(about 1 min to do)
Old Aug 26, 2003
iamboo's Avatar
that too...
SidCivic
Oct 3, 2015 06:00 AM
kmarcet
Sep 26, 2015 10:25 PM
JDMnoob
Aug 2, 2015 02:38 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
