turbo discounters piping
Old Aug 25, 2003
HondaCivicJosh's Avatar
HondaCivicJosh is an unknown quantity at this point
if u have installed the kit does the piping work right. mine
look like they might not run around the engine right. thanks
Old Aug 25, 2003
one more thing
sorry one more thing. in the pics on the instructions it shows
the car with a diff. intake manifold. does this matter? thanks
Old Aug 25, 2003
blckpwdr's Avatar
blckpwdr is an unknown quantity at this point
it will work but I am going to install longer pipe conn. so I can
double clamp them. Because the pipes keep blowing off.
I zip tied the pipe going around the crank pulley to the outside
of the frame to keep it from getting too close.
Let me know after you get it installed. Mine runs really strong but needs to be fine tuned.
Old Aug 25, 2003
blckpwdr's Avatar
I also read your other post. All you have to do is remove the plastic
from under the car. You do not need to remove the washer fluid or
the ac. And by removing the plastic it will let more air go in to help
cool of the turbo.
Old Aug 25, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
It's not just about longer couplings to keep the pipes on. None of the kits out have beaded pipes... big manufacturers bead their pipes. I had all my pipes beaded for $50 so I don't have to worry about **** blowing off.
Old Aug 25, 2003
blckpwdr's Avatar
these are beaded, but the couplings are barely long enough to go over them and clamp down. the clamps aren't very strong and it gets so hot that they slip off from moving around a little
Old Aug 25, 2003
Boosted2k2's Avatar
oh lol.... nevermind.
Old Aug 25, 2003
intake manifold
what about the intake manifold. do i need a different one
or something. the pic has a diff. one.
Old Aug 26, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
no. if u do.. then u need to return that kit .. cause thats gay. granted our plastic one .. is well plastic.. but ull have to spend another 500 for a new one from kms. and if the TD kit makes u do that.. which i know it doesnt... u need to return that sucker
Old Aug 26, 2003
thanks
i wasnt sure if i needed one or not. i guess the only way i will really know if it is going to work is
by taking it to my car and place them where they are supposed to be. not by what i think. thanks guys.
Old Aug 26, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
why in the hell arer people even buying this crap-tastic kit at all??? SF RULES!!!
Old Aug 26, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
ditto~~~~~~~~~~~~~~~~~!!!!!!!!!!!!!!!!!
Old Aug 26, 2003
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
what beading??
HondaGuy7
Feb 22, 2016 01:00 PM
twd000
Oct 4, 2015 12:52 PM
Cam Diaz
Sep 29, 2015 07:17 PM
