SF 1/4 mile time!!! 13.902@102.79mph
Old Aug 8, 2003
PdchasinR6's Avatar
PdchasinR6 is an unknown quantity at this point
i went to Keystone Raceway yesterday (thursday) and wasnt expecting to do very good at all b/c my air/water intercooler was once again not functioning b/c my pump keeps breakin on me. lol, anyhow, started out running a 15.2@94 which i thought was how the night was going to be. Got an idea to pack ice on top of the intercooler and see if we could get a charge and ended up packing 3 bags all over the car....there was about 15 minutes in between the runs so there was plenty of time to get the car cool again. had the air pressure at 27psi in my crappy all-season BFGoodrich vr4 tires and managed to keep the car running 14.3 and lower passes all nite long somehow. Boost was at 7-8psi all night long. My second to last pass was the 13.9 pass, i had wheel hop the whole way through 1st and burned the tires off the whole way through 2nd but the car was sure moving. I have to take a shot of my timeslip so i can post it b/c im sure most people wont believe me, lol. Me and Mike at SF couldnt understand how i got the car to run 13.9 at all but the car was just right and the launch was just right i suppose.
Old Aug 8, 2003
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
YAY!!!!! good job!!!!!!
Old Aug 8, 2003
PdchasinR6's Avatar
Old Aug 8, 2003
RoBBUsaF's Avatar
try it at 12psi!!!
Old Aug 8, 2003
PdchasinR6's Avatar
also for the record, thats with 93 octane pump gas...no working intercooler, and no alcohol injection
Old Aug 8, 2003
PdchasinR6's Avatar
eh....already blew the headgasket once, dont need to get the boost that high again until i've got my low compression pistons in
Old Aug 8, 2003
PdchasinR6's Avatar
oh and of course thats the one run that my friend didnt tape...all the other 7 are on film but that one, figures.
Old Aug 8, 2003
RoBBUsaF's Avatar
how did they blow??? because you turned it up too high??? hmmm. i am planning on going to 12 psi tomorrow. tell me it was from nitrous. please.
Old Aug 8, 2003
RoBBUsaF's Avatar
do you hit 4th on your 1/4?
Old Aug 8, 2003
PdchasinR6's Avatar
i was runnning 9psi and at the time my intercooler was working properly and me and a friend packed it full of ice...the drop in pressure was letting me see 4-5psi on my gauge so stupid us thought thats wat we were actually runnning and so we turned it abck up to 9psi which was actually going from 9 to 13-14psi so we drove it up at 13-14psi for 20 min b4 the headgasket blew....boy was it fun though
Old Aug 8, 2003
PdchasinR6's Avatar
i was sooooo close to hitting 5th....the ex's have shorter gears in them so i get a little farther than most on the 1/4 mile
Old Aug 8, 2003
RoBBUsaF's Avatar
are headgaskets easy to replace?? hmmm... so because the ice made the pressure drop, it was still going just as fast as you had it on 9psi if not faster but it showed 4-5psi... and with the ice still in it, you bumped it to 9 which would be like 14 psi w/o ice?
Old Aug 8, 2003
RoBBUsaF's Avatar
OoooOOOo. ok. almost hitting 5th. gotcha. that's odd. i guess our gear ratios are shorter... most people have said you shouldnt be going into 4th on the 1/4 but i guess that would be correct if you were n/a? or am i retarded... blah its late.
Old Aug 8, 2003
PdchasinR6's Avatar
u got the concept there bud.....um, me and my friend took about 3hrs to get the motor and tranny out, took us another 4hrs to install the clutch, check the head, replace the headgasket, put a block guard in, reseal the oil pan again, and put it back in the car and have it running.....total about 7hrs from start to the time the car ran
Old Aug 8, 2003
CivicSouldjaEX's Avatar
I guess... lol
Old Aug 8, 2003
PdchasinR6's Avatar
yeah...forget what people say, just drive the hell outta it til u cross that line, lol
Old Aug 9, 2003
EnProceso's Avatar
awesome man, imagine what you could of did with your stuff working! fix it, ice it, run it and get back to us!
Old Aug 9, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
WOOOORD UP bro... im gonna hit high 13's too at 7-8 psi i hope... but i have a little more done, and inm lighter... we'll see... or maybe not if BOVs never come.... HURRY WITH EM whoever is sending them to SF..... damn...
Old Aug 9, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
You should put on your steelies when you run rsx. Those 17's or 18's won't help you reach your goal.
Old Aug 9, 2003
C2i0v0i1C's Avatar
SuperMODrizd
and what kinda pistons are u planning on getting, i got a picture of mine in the rides section
Old Aug 9, 2003
damn 2i0v0i1c... where you buy them pistons? ive seen them, just wondering how much you dropped on them.. and did you do anythinig like micropolish or knifeedge crank?????
Old Aug 10, 2003
C2i0v0i1C's Avatar
SuperMODrizd
pistons came from JE they are 9:1, and dish style, with the way my setup is my CR is like 7.2-7.8 to 1, the pistons came with no valve seats but then again the stock valve seats look like little nicks on the top of the piston. i think they were like 500-550 or something id have to look at the bill that i dont have in front of me right now, honda cranks can take alot more power than im going to be able to give to it, so i didnt touch the crank
Old Aug 10, 2003
WHAT DID YOU DO TO DROP THE COMPRESSION THAT MUCH AFTER PSITONS???????? NO way the head gasket is that damn thick...
Old Aug 10, 2003
zinkyroo's Avatar
cool beans
LETS NOT TALK IN CAPS...
Old Aug 10, 2003
C2i0v0i1C's Avatar
SuperMODrizd
first the pistons are dish, since there were no valve seats in them we put 2 head gaskets in, and then at top dead center the piston was still a few mm from the very top of the cylinder, the shop doesnt do a compression test, so its a guesstimate
CarStuff
Dec 6, 2020 12:52 PM
mattdoc
Mar 14, 2017 12:10 PM
sccarally
Texas
May 17, 2015 10:11 PM
bsmiley
Apr 27, 2015 01:27 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
