ok if the LX runs a 13.6 with the kit
Old Aug 4, 2003
ironcow's Avatar
ironcow is on a distinguished road
then what is my EX going to run with the same adjustments and fine tuning?
and have you gotten a dyno with the 9psi boost yet?
i recall you guessing 215?? dunno
any ideas
Old Aug 4, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
13.55
Old Aug 4, 2003
ironcow's Avatar
at least i get 1 reply with 20 + views
Old Aug 4, 2003
iamboo's Avatar
Retired - SoCal FI Mod
it's hard to say... i think our engines would perform almost identically... maybe a tad bit faster but still not too far off the lx time...
Old Aug 4, 2003
rscivic's Avatar
rscivic is an unknown quantity at this point
I think it is going to depend on what psi we are running don't you? I just put on the kit and while there are some differences I am waiting to get the boost controller to really see what hp and put it on the dyno.
Are you doing the alc injection kit ironcow?
Old Aug 5, 2003
Boosted2k2's Avatar
I'll put a real answer instead of leaving my 13.55 lol. There shouldn't be a big difference. They are essentially the same engine. If there is any difference, it would probably be attributed to the EX's higher compression ratio.
Maybe you can say that a rough estimate would be that the EX will have 7-8% more horsepower than the LX. An LX @ 200whp, would probably have the EX at 214 or so. It's a little more HP, but not enough to make a big difference.
Old Aug 5, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
i think they run about the same due to weight..... ex is almost 200 lbs heavier than my car... (dx, NO A/C, NO PWR, NO sunroof, NOthing in trunk).... so i think i could take one by 1/2 car or so...
Old Aug 5, 2003
Diemos's Avatar
Diemos is an unknown quantity at this point
Still, it has been proven that the EXs are quicker. With all that you have done you might run side by side, or a little slower than an EX. There is a noticably small power increase in the EX.
Old Aug 5, 2003
not always quicker, with a turbo, your talking 10 morewhp at max!!!!!!!! the 200lb weight diff max big deal, trust me!!!! also, dx tranny is longer, which is better for turbo... i know i can take an ex.... 200lbs is better than 10whp... hell, i can take one now with the same bolt ons as my car i/h/e... so why not turbo'd, ESPECIALLY since with the lower compression ratio i figure to run 7-7.5 lbs on the street, and i wouldnt puch an ex over 6....
oh... and by the way, im talkin about taking out EX's WITH MY 19's ON!!!!!
Old Aug 6, 2003
ironcow's Avatar
where does vtec come in to play here? or does it at all?
Old Aug 6, 2003
CivicSouldjaEX's Avatar
taking EX's eh? You must be good driver.
doncarbone
Jun 8, 2015 03:37 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
hokiedad4
Apr 30, 2015 07:18 AM
cloudguy
Apr 28, 2015 05:02 AM
supercivic01
South
Nov 30, 2001 11:27 AM
