D17A1 turbocharged... ODB II problems...?
Old Aug 3, 2003
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
Hey dudes..
I'm planning on turbocharging a D17A1 engine and I've gone through some speedbumps.. I've been told by some people that the ODB-II computer will not like the turbo and the check engine light may come on constantly as a result of adding a turbocharger.
What is the guaranteed way I can make a turbocharger with for my car. I will aquire a compressor (internal wastegate), intercooler, blowoff valve, and a bunch of plumbing from a source.. as I am not purchasing a package. (so I'm not buying a kit but I'm buying seperate parts from different places.. compressor is from an 99 Eclipse) I need to know now I can make sure this is successful.
Is there a company out there that reprograms my ECU to understand that there is nothing wrong with my engine and that there is added boost? Cuz I heard ODB-II will give me some problems.. because of the super tight emission standards in the D17A1.
I've been told that if I boost 6 or 7 PSI.. the check engine light should not come on.. unless I install it wrong or I boost over 10 psi. Is this true?
Should the D17A1 block be able to handle 6 or 7 PSI or should I have it sleeved to be certain?
Please help!
-Spleeny
Old Aug 3, 2003
iamboo's Avatar
Retired - SoCal FI Mod
map sensor isolation valve... this prevents your ecu from dectecting boost... ya know.. the thing that the obd II doesn't like... i think you can find it for like 60-70 bucks somewhere...
Old Aug 3, 2003
NoSpleeny's Avatar
So all I need is like a "software patch" for the ECU? the ECU won't recognize the boost because the Map Sensor Isolation Valve is not good at detecting boost?
Old Aug 3, 2003
C2i0v0i1C's Avatar
SuperMODrizd
u dont need ne thing for the ecu, re read what he said....the map sensor tricks the ECU, no software patchs or whatever ur talkin about
Old Aug 3, 2003
NoSpleeny's Avatar
Where can I buy a MAP sensor isolation valve? Any idea would be helpful.
Old Aug 3, 2003
C2i0v0i1C's Avatar
SuperMODrizd
http://www.synapseengineering.com/html/ml004.html
Old Aug 3, 2003
NoSpleeny's Avatar
Thanks man!
Old Aug 5, 2003
blckpwdr's Avatar
blckpwdr is an unknown quantity at this point
does anyone know if you need the map sensor isolation
valve for the t.d. kits
Old Aug 5, 2003
rscivic's Avatar
rscivic is an unknown quantity at this point
What about Jet? I think that if you send them the specs on all of your upgrades they will adjust your ECU for you.
Old Aug 5, 2003
yourinmyw0rld's Avatar
i emailed jet they told me to talk to aem
Old Aug 5, 2003
CarbonFly's Avatar
I thought our cars were ODB III?
Old Aug 5, 2003
C2i0v0i1C's Avatar
SuperMODrizd
obd III is right and yea talk to AEM so they can get 1800 for their plug and play
Old Aug 5, 2003
HondaCivicJosh's Avatar
HondaCivicJosh is an unknown quantity at this point
is this going to happen to me if i run 5psi?
thanks
Old Aug 6, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
YOU ARE WRONG... Our cars are obd II.. if you don't believe me, go and look under your steering column and it says OBD-II right on it! I just noticed the sticker today... weird!
Old Aug 8, 2003
wenlyone's Avatar
wenlyone is an unknown quantity at this point
Search for check valve or missing link, that is what they are named in the stores.
Old Aug 8, 2003
wenlyone's Avatar
There is a ODBIII now???
Old Aug 9, 2003
wcsjunior's Avatar
Supreme Member!
i've seen pics of it... where would it be connected to?
Old Aug 9, 2003
iamboo's Avatar
what the hell is OBDIII... never heard of it..
Old Aug 9, 2003
wenlyone's Avatar
my thoughts exactly.
Old Aug 9, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
You dont even need a map isolation valve if u dont plan on boosting more than 10 psi
Old Aug 9, 2003
wenlyone's Avatar
huh?
.... at anytime, if stock map sees boost you are going to get check engine... regardless at what psi.
Old Aug 9, 2003
zinkyroo's Avatar
cool beans
Nope Honda MAPS are good to about 11 psi. Go ask on Honda-Tech if you dont believe me
Old Aug 9, 2003
iamboo's Avatar
what would a honda tech know about cars??
Old Aug 9, 2003
wenlyone's Avatar
The honda map sensor is good for 1 bar (14.5 psi), so yes it is good for 11 psi... But that is not the problem. The stock ecu needs the reading from the map sensor to give the correct fuel from the fuel map. But since there isn't a boost map, the check engine light will come on. When check engine light comes on, many things can act funny, and let's not even talk about not passing inspection.
a check valve or missing link will solve that problem, that is all it is for. The ability of the sensor has nothing to do with missing link...
and yes, many people on honda tech are old timers, 11psi might be a little old on that note. But as you know, some people do pass old knowledge to the new generations, even if they don't apply to the new cars.
I think before I totally understand what the returnless fuel system is all about, I am probably the same way on viewing the turbo setups.
Old Aug 9, 2003
zinkyroo's Avatar
cool beans
Hehe. A lot more then the people on this forum.
Old Aug 9, 2003
wcsjunior's Avatar
Supreme Member!
so wait, the check engine light would come on, but does that mean that the car would be cutting off at low RPMs?? cuz if its just the check engine light, then i dont think most ppl dont care as long as it doesnt affect the performance or daily driving.
Old Aug 9, 2003
iamboo's Avatar
on EX and HX motors, the vtec won't kick in when the check engine light is on...
Old Aug 9, 2003
wenlyone's Avatar
Very good.
And if the new ecu also have a limp mode, the car will run more sluggish.
Old Aug 9, 2003
wenlyone's Avatar
Nah, I am here now.
Old Aug 10, 2003
old beater's Avatar
old beater is an unknown quantity at this point
the car runs fine if the check engine light is on, with a turbo or nitrious i wouldnt try it but in my car with pullies,intake,exhaust,clutch,header. i ran a 15.5 with the check engine light on and v-tec still kicks in. it might not however if there is a real problem. mine is only on cause the front half of my cat went missing, so the code is for front catalyst not heating up right. if it was for low oil pressure or something then i bet it runs in "limp" mode and v-tec would not kick in.
