dynoed my EX
Old Jul 25, 2003
  #31
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
with just a 50 shot (if the engine could hold it) you would make more than 250whp, just due to the fact that you are cooling off the air from 100 degrees to -175 degrees. That alone will add 30-40 whp then you add the 50 shot. Thats a big increase.
Just slap a 20 or 35 shot on there to make 230whp.
Old Jul 25, 2003
  #32
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
do you think our d17 can handle that much power?
i think ill let someone try that out first.
Old Jul 25, 2003
  #33
Catalyst's Avatar
Dont worry, i will test it out for you guys. ok?
I am soooo serious. I have a direct port kit sitting about 16 inches from here. And a single fogger kit next to that, and a plate system next to that.
I like Nitrous. lol
Old Jul 26, 2003
  #34
trick000's Avatar
trick000 is an unknown quantity at this point
that's a wierd dyno... where RPM should be they have MPH. I guess you could get RPMs from that, but then you'd have to know what gear you were on and the diameter of your wheel during the run.
Once you get RPMs, then you can just plug in the HP at that RPM with this formula: torque = HP * 5252 / RPM
Your HP and torque should cross each other at 5252 RPMs. If it doesn't then something is wrong.
Old Jul 26, 2003
  #35
CIVIC808's Avatar
thats the thing they couldnt get the reading for the rpm.but they did it on third gear and my wheels are 18'' with 35 series.
Old Jul 27, 2003
  #36
5PEED EX's Avatar
5PEED EX is an unknown quantity at this point
So whats the WHP on 9psi on just regular bolts on's ? (intake, exhaust,pulleys)
Old Jul 27, 2003
  #37
Catalyst's Avatar
different dyno's use different calculations. All of them are not TQ*5250 = whp. They use different calculations to make use of different parts on the dyno, and they usually come really close to the industry standard for accuracy.
Old Jul 28, 2003
  #38
trick000's Avatar
ok here's what I got... I think it's right but if it isn't oh well.. it's free.
The final gear ratio is off of a civic coupe manual EX which is 4.41.
Third gear ratio is 1.24. If you look between 70 and 75 mph, that is where 5252 RPMs is and that is where your torque and hp cross.
So according to the graph max torque is around 192 ft/lbs at around 4100rpms.
I guessed your wheel diameter from the tire calculator on this site. I used 24.8 inches on the equations. A difference of 1 inch can mean a difference of about 8-10 ft/lb of torque in the calculation.
Old Jul 28, 2003
  #39
cdmx's Avatar
How come that Si got alot more power at lower boost?
Old Jul 29, 2003
  #40
CIVIC808's Avatar
wow my peak torque is higher than my max hp.
Old Jul 29, 2003
  #41
Catalyst's Avatar
for some reason these engine make way more torque than the D16's
Old Jul 29, 2003
  #42
SaiyanMatador's Avatar
SaiyanMatador is an unknown quantity at this point
hhehe DOHC VTEC, i believe the new si's have a 2.2 or a 2.0? thats why, more power to begin with, including more potential for power becuase of the larger engine!
Old Jul 31, 2003
  #43
SlammedBlueEM2's Avatar
All Eyes On Z
Best thing I heard about our cars since the first K20A2 swap.
Old Aug 2, 2003
  #44
deeznuts's Avatar
deeznuts is an unknown quantity at this point
ok where can i order my sf turbo and what setup would be recommended. i have stock internals, and only mods left after turbo would be aem cam gear, cat back exhaust. if possible i would want a turbo back cat-less exhaust 2.5 in. in wi certain places don't have emissions testing
Old Aug 2, 2003
  #45
aznrj's Avatar
aznrj is an unknown quantity at this point
a single cam. 1.7 honda engine.. able to handle all that..50 shot of nitrous, even turbo charged..did i say on a single cam?wow... i don't wanna test my luck on my investment..well my moms investment for me... when i graduate college, hopefully in a two years, amma loose this single cam banger and get a turbo charged car...
Old Aug 2, 2003
  #46
Catalyst's Avatar
i went 13.6 @ 101.887 MPH on 9 psi with the base kit.
Old Aug 2, 2003
  #47
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
Bigger motor 1.7 vs 2.0
Bigger turbo T3 vs T3T4E
Bigger turbos work more efficient and crate less heat than smaller turbos. They however take longer to spool.
sergio73
Jun 23, 2015 03:21 AM
DC5@EM2
Bolt-on Engine Performance
42
Jun 27, 2002 10:47 AM
iceman
Apr 11, 2002 03:09 PM
Jhonda
Mar 20, 2002 10:26 AM
CapYoda
Nov 29, 2001 07:37 PM
