FS: 2 Infinity Kappa Perfect 10.1
Old Aug 13, 2006
SLO REX's Avatar
250+ awhp Stage 2
Got two Infinity Kappa Perfects 10.1 in a ported box with a Infinity Reference 7521a. Looking to get around $550 OBO. Used maybe a week, took out because I cannot take corners fast in my car now because it slides. Subs are perfect and they bump hard for the amp only being a 97 watt RMS x 2.
SUBWOOFER SPECS:
# 10" 4-ohm subwoofer
# aluminum cone with high-roll butyl-rubber surround
# massive cast-aluminum basket
# suitable for free-air use (handles up to 175 watts in free-air applications)
# recommended power range: 75-350 watts RMS
# peak power handling: 1,400 watts
# frequency response: 18-200 Hz
# sensitivity: 94 dB
# top mount depth: 5-3/4"
# sealed box volume: 0.6 cu. ft.
# ported box volume: 1.0 cu. ft.
AMP SPECS:
» 2-channel car amplifier
» 97 watts RMS x 2 at 4 ohms (142 watts x 2 at 2 ohms)
» 283 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
» variable high-/low-pass filters (32-320 Hz, 12 dB/octave)
» variable bass boost (0-12 dB at 50 Hz)
» MOSFET power supply
» CEA-2006 compliant
» Tri-way capable (Tri-Way Crossover required)
» preamp- and speaker-level inputs
» preamp outputs
» fuse rating: 30A x 1
» 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
» 12-5/16"W x 2-11/16"H x 12-1/8"D
Old Aug 20, 2006
SLO REX's Avatar
250+ awhp Stage 2
Bump!
Old Aug 29, 2006
SLO REX's Avatar
250+ awhp Stage 2
Bumpo!
Old Sep 10, 2006
SLO REX's Avatar
250+ awhp Stage 2
bump $525.
bump for an Ohio State win!
Old Sep 15, 2006
SLO REX's Avatar
250+ awhp Stage 2
Bump $515
Old Sep 26, 2006
SLO REX's Avatar
250+ awhp Stage 2
bump need money for rent!!!!!1!1!1!1
Old Oct 6, 2006
SLO REX's Avatar
250+ awhp Stage 2
Bump
Old Oct 6, 2006
SLO REX's Avatar
250+ awhp Stage 2
Bumpola
Old Oct 9, 2006
SLO REX's Avatar
250+ awhp Stage 2
Bump need gone ran into a snag with my WRX and just bought a $575 downpipe.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
rallyeredem0
Nov 2, 2015 10:56 PM
Munzy
21
Oct 7, 2015 07:48 AM
Wariogamer
Sep 29, 2015 09:49 AM
