Question For Speedfetish or Anyone
the rotor is the only thing i need to know about. Will it bolt up to the 02 SI spindle. IM get5ting the rear disc setup from the 02 SI all i will be using is the ROTORS from the 95 Civic. Everything else will be from the 02 SI including the relocation brackets for the calipers.
I did some research of my own. The 95 Si and the 03 Si AEM kits are the same according to AEM. Since all i will be using is the rotors from the 95 kit and the hardware, relocation brackets, and calipers from the 02 SI everything should work fine and ill be the ONLY one with AEM rear disc brakes utilizing the lighter two piece rotors. KICK A$$
IM using the 95 front rotors on the rear spindle of the 02 SI. Since the bolt pattern has been the same itll fit. AEM said they are the same kit. So ill take AEMs word for it. The hard part is obtaining the relocation brackets and other pieces from the 02 Rear kit.
00 Hatchback Owner
hmmmm i duuno where they took it , but i seen it on I-45 on my way home yesterday when i was coming back from the shop...www.speedfetish.8m.com
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
