DIY: Torque mounts using urethane.
Old May 20, 2008
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Thought I would post this for reference. Really interesting stuff.
http://www.raktron.com/misc/mt.htm
http://www.8thcivic.com/forums/do-yo...ml#post2725552
http://importnut.net/motormount.htm
Old May 20, 2008
sl33pyriceboi's Avatar
Re: DIY: Torque mounts using urethane.
good info...
Old May 20, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
repost but good info!
Old May 21, 2008
Here's an alternative method below. Read the whole thread though. Don't get the wrong impression though. A lot of people use windo-weld and it works. But ****, quicksteel seems so much better...
"Yes agree about windo weld (garbage) but like i said inserts only cover 3 torque mounts which leaves the top mounts to take all the brute force and believe me they will wear out real quick so torque mount inserts+quicksteel in top mounts= Perfect combo if u dont mind rattling a little at idle and you can wrap it up and have it all done in under two hours "
http://www.honda-tech.com/zerothread/1941796
Old May 22, 2008
Yup, so I ended up taking off the 3M stuff and adding the quicksteel "putty." Holy crap is that stuff easy to work with! You just mash it together until it's a uniform color, then squish it in. Gets hard in 5 minutes. Gloves are mandatory.
So I got them in there, and yeah, the car shakes a lot. I'm really glad I didn't pay 40 bucks for the ES inserts. All it takes is 3 tubes of quicksteel for 15 dollars and it does the same thing. Shifting is SO much cleaner. It's a breeze shifting gears. My car still shakes a little on 1st and 2nd at certain points in the clutch engagement, but much improved.
I'm going to see if I can add windo-weld around the bolt (inside the metal "tube" that the engine mount bolt passes through). There is plenty of space around the bolt for the stuff to go into. My plan is to add WW into there, then completely remove the nut that slips onto the bolt. So in other words the bolt will have a big cusion of WW around it. That should eliminate the vibration while still having the benefits of the restructured mounts.
But for now, I want to see if they can break in or wear in.
Old May 22, 2008
01HonderCivic's Avatar
Don't be a n00b, search ftw
Old May 22, 2008
Originally Posted by 01HonderCivic
^_^ Haha.
Old May 22, 2008
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
old school mod right here!
Old May 22, 2008
Stay away from quicksteel guys! I mean it. It just cracks and breaks off. There is no point to using it, unless you want it to last 2 weeks. I just lost 15 dollars and time right there. Oh well, live and learn. At least I can warn everyone now.
Yeah, 3M windo-weld is the tried and true method. It takes a **** load of time, but it's nice and flexible. But you better make sure that you clean off the old mounts perfectly, because you want the WW to bond to it.
mgrantaz
General
May 2, 2022 05:40 PM
twd000
Oct 4, 2015 12:52 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
rovafa2002
Sep 28, 2015 06:57 PM
FistRock
Sep 4, 2015 08:00 PM
