Cold Cathode DIY
Old Oct 30, 2006
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
Cold Cathode DIY
This may have already been covered, but, what the hell.
If there are any questions, feel free to shoot me over a message.
Keep in mind, this is my first DIY.
1) The First Step is pretty self explanatory. Disconnect your battery.
2) Pop your trunk, and crawl on inside. If you look up you'll see the following, if laying on your back in the trunk as I was doing.
The wire you're going to want to grab and follow is the wire that is T'ed off from the other. It goes to the back where the existing trunk light is. The wires are wrapped in one of those plastic things. So get it open and you should see a yellow wire with a blue stripe and a red wire. The yellow wire is power, and the red wire is the ground.
3) Cut the wires at a place nearest towards the end of the light.
4) Gather your cold cathodes and plug them into the transistor(I think is what it's called) Next, cut the switch off of the transistors. You should now have a transistor with red and black wires coming off of it on one end, and the wires to the cathodes coming out of the other.
5) Tap the red wire of the transistor to the yellow wire in the trunk. Next, tap the black wire of the transistor into the red wire of the trunk. Solder, tape, whatever you wanna do. Just make sure it's secure.
6) The Cold Cathodes come with velcro tape, which I used at first. This did NOT hold up well at all. I strongly advise using 3M double sided tape. You can get it at Wal-Mart. Mount your cathodes wherever you would like. I cut off a small strip of 3M and put it on the end of each light. I cut off a larger strip for the transistor and mounted it right up near where the old light used to be.
7) Connect your battery, and stand back and check out your nite brite trunk.
Make sure everything is secure!
BTW, I got my lights from xoxide.com
Old Oct 30, 2006
BRED civic's Avatar
BRED civic is an unknown quantity at this point
hey thats awesome! didnt you blow your fuse?... the stock light is 5.7V
Old Oct 30, 2006
thefever's Avatar
I need a drop
nope. not yet. been installed for about 2 months.
Old Oct 30, 2006
red_civic_boi's Avatar
red_civic_boi is an unknown quantity at this point
and yall could connecting to the speakers wires then you will have Beat to the Sound for your neons hahaha....is my idea good? haha
Old Oct 30, 2006
ryangt's Avatar
ryangt is an unknown quantity at this point
diy
good job on your first diy, most people are too scared to jump into their wiring..... way to not be afraid you big burly man you
Old Nov 4, 2006
Rufus's Avatar
Perhaps thats the best idea anyway. I hooked mine to 12V and it killed every invertor.
Old Nov 4, 2006
thefever's Avatar
I need a drop
Hmm. that's interesting. Im not sure what to tell you. I went with the easiest way, and it worked pretty well.
Old May 21, 2007
dubD02CiViC's Avatar
dubD02CiViC is an unknown quantity at this point
Re: Cold Cathode DIY
What fuse is the one for the trunk light?
Old May 21, 2007
i think that is ?small light? fuse or ?interior lights?. its in the engine bay fuse box
Old May 21, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
nice DIY
Old May 21, 2007
Yea i just found that, thanks gearbox i was looking in the interior fusebox before.
jtcavey
Sep 30, 2015 02:18 PM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
Nalmonte
Sep 28, 2015 01:10 PM
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
