i need 90k major service
Old Oct 16, 2006
chicohonda02's Avatar
Since 2002 Baby!
Exclamation i need 90k major service
I need to get this done. Can someone go over this and see if this list of correct. I can't find the manual. Any recommendations? Spark plugs,etc? Timing belt gets done.
Replace air cleaner element
Inspect valve clearance
Inspect fuel pipes, hoses and connections
Replace spark plugs (only if running copper plugs)
Replace engine oil
Replace engine oil filter
Inspect alternator drive belt
Inspect cooling system hoses and connections
Replace timing belt
Inspect water pump (recommend replacement)
Inspect exhaust system components
Replace manual transmission oil
Inspect clutch release arm travel
Inspect brake pad thickness
Inspect brake discs
Inspect brake calipers
Inspect brake hoses and lines
Inspect parking brake
Replace brake fluid (including anti-lock brake system)
Inspect anti-lock brake system operation
Inspect front wheel alignment
Inspect steering operation, tie rod ends, steering gearbox and boots
Inspect power steering pump
Inspect power steering hoses and lines
Inspect power steering pump belt
Inspect suspension mounting bolts
Old Oct 16, 2006
gh0st's Avatar
TAQUITOS!!!!
I thought timing belt wasn't included in the 90K. I was under the impression that it was a separate service
Old Oct 25, 2006
Since 2002 Baby!
the guy at the shop, set its usually done at 110K, but if a major is done @ 90k, they can see if it needs it. might as well change it.
that's why i'm asking you guys!!!
JetsterDajet
52
May 8, 2016 12:11 AM
WWJD
Sep 23, 2015 12:56 PM
Jrosa
Sep 14, 2015 08:24 PM
