want to remove my tint
Old Aug 22, 2005
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
Anyone know any good shop around SF or near SF that does remove tint without damage my windows? I planning to remove back and two side windows , and i heard it hard to remove the back windows because they have defoster wires that stick into the back windows.
Old Aug 22, 2005
CRX_Becca's Avatar
My CRX is stocker than yours
CRX_Becca is on a distinguished road
I want to do the same thing on my CRX. Everyone's telling me it's a DIY kind of job... just get a steamer and a razor blade... oh yeah... and be real careful on the back window.
Old Aug 22, 2005
jttegx's Avatar
OMNES AD UNUM
if you dont have exp. with removing tint, i wouldnt suggest removing the rear unless you know what your doing. ive read an article where a garbage bag was ripped up and used to stick onto the rear tint and was wetted then eventually dried so it could be pulled easily but i still wouldnt try it for personal reasons.
the side windows shouldnt be too hard. need a fairly large razor or blade, slash a cut somewhere and pull away. pull slowly and try to pull as much as you can. some amoneia* (sp) can help cause ive heard of that stuff removing tint from windows. i think windex usually has amoneia in it? if not that, some lightly soaped water.
shops usually charge $30 to remove tint on the front 2 windows, prob 20 for sides, and most likely another 20-30 for the rear.
any tint shop would be fine. as long they know what there doing
Old Sep 11, 2005
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
Post
DIY for removing tints..
Things needed:
1. Goo-Gone (or any similiar product.)
2. Razor blade (w/ razor scrapper tool)
3. Invisble window (or any similiar product.)
4. Alot of patience (most importantly)
Getting started:
* The temperature of ur glass should be over 80 degrees (normal temp on a hot day).
* Start from the front and work ur way to the back.
* Another trick is to actually turn on ur defogger and heat and let it run thru out the removal process.
FRONT AND SIDE WINDOWS
Step 1: * Roll ur door windows down a little and scrap at the edge (prefferably an area without the defogger lining for the winshield).
* If you can't find a suitable area to start cut an area in the into the tint scrape it unitl u have enuff tint to pull at.
* You shouldn't have to scrap all the tint off if the temperature is right.
* First try slowly pulling off the tint slowly (very very slowly this usually works).
* Try to go around the edges and then go to the center.
* If excess tint is remaining scrape away (excluding rear window).
* If excess goo remains apply Goo-gone with a clean cloth (you can also u those green rough thingys u use to wash dishes) and rub dry/off with separate dry cloth until window is clear.
* Clean the window with a suitable automotive window cleaning product.
REAR WINDOW
Step 1: * Let the defogger run for a couple of minutes (The inside of the window should be hot for the skin of ur back hand).
* Start form the roof area and work ur way down to the rear deck.
* At the edge of the defogger lines scratch(the edge) or scrape enuff tint to pull at.
* The rear window needes the most patience. Work ur way from top to the sides to the bottom.
* A good technique when working on the bottom is pushing the tint down slowly.
* Remember the rear window is alot bigger and has less space to work with so ocassionally cut off some of ur pulling tint to give urself a better view and more space to work with.
* The 3rd barke light area is tricky a second hand to push down the rear deck is a big help.
* When ur done apply the Goo-gone (note only use soft cloths for the rear because u don't want to abrase the deffoger lines) and rub over the glass evenly, let it sit for 30 secs or less then rub away with dry cloth till surface us clear.
HOPE U GUYS FOLLOWED THE STEPS CAREFULLY AND HOPEFULLY IT CAME OUT GREAT WITH EASE.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
spyder13
Jul 31, 2015 06:31 PM
Misfit2613
Jul 30, 2015 09:49 AM
greenbackz
Jul 30, 2015 12:04 AM
Jul 14, 2015 03:39 PM
