need help.....
Old Mar 28, 2005
S2KREY's Avatar
formerly 2k1CivicRacer
S2KREY is on a distinguished road
need help.....
i dunno if i need a allinment but my stering wheel slightly shakes around certain speeds (45-80 est).... i just got finished replacing my cv joint/shaft my tires seem fine nothing loose, so you guys think it might be that i need an allainment after the intsall? b/c i dont want to spend more money on things that wont be needed... thanx in advance....
Old Mar 28, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
I noticed this too when i put my wheels on. Did you recently do that??? If so then its an characteristic of the small side wall flat surface tire gripping the raod. I put front and rear strut bars on and noticed quite a bit of diff. in the way it handles and in the way it drives. Hope this helps let us know!! Chris
Old Mar 28, 2005
S2KREY's Avatar
i dont think its my wheels... ill prolly go out on fri and get a wheel balance and allinment... if i cant figure it out by then... thanx... more suggestions anyone...
Old Mar 28, 2005
allmotor's Avatar
nor cal 7thgens
same **** is happening to me, but i have the stock wheels and tires?
Old Mar 28, 2005
gh0st's Avatar
TAQUITOS!!!!
hit any big potholes recently? wouldn't hurt to check out balance & alignment
Old Mar 29, 2005
S2KREY's Avatar
yeh ill just head out and get a balance and allingment... let u guys know if the problem gets fix or not.... gettingit done fri
riftan
Jan 16, 2015 10:04 PM
rpca
Nov 10, 2011 11:00 PM
d0wnShiFt
May 1, 2011 04:40 AM
d0wnShiFt
Apr 29, 2011 01:46 PM
cessna228
Jun 5, 2010 01:55 AM
