should i get spring or coilovers
Old Jan 12, 2004
heyitziak's Avatar
suffering the heat in my black civic
heyitziak is on a distinguished road
i m thinking about lowering my car, but i dunno if i should buy a spring for like 100-200 dollar or save up to buy tein basic or tein ss coilovers. if i were to get the spring do i need to get camber and new shock for it or no. cus i dun have a lot of money but want to lower my car.
also if i m thinking about getting 19" wheel, how many inch can i lower my car yet not touch anything that i m not suppose to thanks
kevin
Old Jan 12, 2004
civicguy777's Avatar
civicguy777 is on a distinguished road
if you can save to buy tein's do that, otherwise if you just want to lower your car buy some springs but u will have a bouncy ride till u get ur shocks done...i just have eibach's sport lines and they are not bad at all...
Old Jan 12, 2004
19"'s i dont think they'll fit?????
Old Jan 12, 2004
Weaponx12o's Avatar
19's will fit. it just might rub in the fender well on the front when turning. just as long as you have it lowered no more than 1.75" then you should be fine. i say save and get teins, but it is cheaper to just get springs
Old Jan 12, 2004
DizWikedCivic's Avatar
springs have a better ride than coilover, sleeve coilover that is, such as skunk2, GC, etc.
Teins SS are full coilover, which comes with shocks. it design to have a better ride than springs with stock shock or sleeved coilover with stock shocks. spring are like what 100-200 bux, sleeved coilover are bout 200-300, full coilover about 650-1000+
remebering the lower you go, the more harsh your ride gonna be. a camber kit is never needed, not even with a 5" drop, it just recommended, getting a camber kit will save u buying alot of tires in the long run, and tires aint cheap,
for 19s, i wouild probably get 215/35/19, it all depend on your camber, pending if it rub or not, i think u cant go no more than 2" if you got 0 degree camber, im guesin camber need to be alteast negative 1.5 degree so you wont rubbed, front wont be no problem, just for the rear
Old Jan 12, 2004
KeNsHiN's Avatar
LEVA
i would save up and get the set up that you really want.
Old Jan 12, 2004
heyitziak's Avatar
how much does a good camber kit cost
Old Jan 12, 2004
AntDeezy's Avatar
if your going to go wit 19's, I would get something adjustable .....
Old Jan 12, 2004
Weaponx12o's Avatar
around 100 for the rear.. 20-30 for the front. anything over is a rip off. get spc or ingalls
Old Jan 12, 2004
AntDeezy's Avatar
i had intended on getting shocks and springs until i found out what it took to install the Koni shocks .... and that they are the only ones out there for the 7thGen .... would have set me back about $650 total and would have had an excellent ride .....
Old Jan 12, 2004
JayFReaZy's Avatar
get the hayame coils! It seems like they're great for 650 shipped. It comes with upper mounts and a built in camber I believe? Dezod is doing a GB on them, for even cheaper than 650! Check out the GB forum. And for the review check out the Suspension forum.
Old Jan 12, 2004
KeNsHiN's Avatar
LEVA
hayame is the way to go
Old Jan 12, 2004
i got ingalls rear camber kit for sale
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
Tedverseti
Sep 29, 2015 05:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
