Looking for someone who is willing to help...
Old Jul 23, 2003
Stephon314's Avatar
Stephon314 is an unknown quantity at this point
Hi everyone
I had RSX seats swapped in my 01 coupe and I failed when trying to reset the SRS light. I followed the steps for more than 10 times but still it did not work. It did blink twice but then turned on again. Do you guys have any idea what the problem is? I posted in this forum because I live in Bay area so someone might be able to help me in person. If you had swapped your seats and solved the problem, please PM or email me to let me know where I did it wrong. Thanks.
Old Jul 23, 2003
aZnVoYCe's Avatar
Try reseting the ECU.
Old Jul 23, 2003
AntDeezy's Avatar
or try to un hook the battery and re attach it....
Old Jul 23, 2003
Stephon314's Avatar
Thanks guys. I tried to detach the negative part of battery but it didn't work except my radio setting and clock were reset.-__-ll Can you tell me how to reset the ECU? Thanks.
Old Jul 23, 2003
speedracersong's Avatar
http://www.madstatic.com/2k1civic/diy/aemcai/index9.mv
Old Jul 24, 2003
DizWikedCivic's Avatar
take out the negative battery and wait from 15-20 mins
Old Jul 24, 2003
Stephon314's Avatar
Ok guys thanks again! I'm going to try these methods now and wish me good luck!!
Old Jul 25, 2003
Stephon314's Avatar
Hey guys
I tried the method to reset the ECU but still it did not work. I opened the fuse box and took the 7.5 fuse on the right out(Or should I take another fuse that says 7.5 on it?) Waited for 10 minutes, put it back and start the engine for 10 minutes, turn off, turn on and then off, and then turn on again. The SRS lights is still there...-__- Did I do anything wrong or? Please help! Thanks again for taking your time.
Old Jul 25, 2003
Originally posted by Stephon314
Hey guys
y did u do that for, that for the fuel injector, u reset that instead of the srs
Old Jul 25, 2003
Stephon314's Avatar
Well....cuz someone provided a link about it above...-__-ll I didn't think it would help me to reset the SRS but I still gave it a try. I've followed the DIY reseting SRS lights for many times already but it just turned on back right after it flashed for two times. I re-checked everything and all the plugs were connected properly...Any idea?=(
Old Jul 25, 2003
wonderz's Avatar
wonderz is on a distinguished road
hehe, i need to reset my SRS lights too. I'll give it a try tomorrow, if it works, i'll come help u...
if not, then....someone gotta help us, haha
Old Jul 25, 2003
Stephon314's Avatar
Alrite man wish you good luck!=) Hit me back when you succeed...I really don't think I've done any steps wrong but oh well...ttyl
Old Jul 27, 2003
Jeff's Avatar
Jeff is an unknown quantity at this point
go here
srs reset
Old Jul 27, 2003
Stephon314's Avatar
Errr....Thanks for providing the link. But like I said I've followed all the steps from the link before I post this. It did not work after blinking for twice...The SRS light still comes out after 10 seconds I turn on the ignition...=(
Old Jul 27, 2003
wonderz's Avatar
haha, i think i did even worst than you...I can't even see inside the plug, so i just blindly plug a wire in there to connect the 2 pins inside, which doesn't really work. well, probably 'cause its dark outside and I can't see anything...
Old Jul 27, 2003
Stephon314's Avatar
Sorry to hear that, so you sure that you plugged it into somewhere else? What you gonna do with it now? I don't really want to spend something like $30 for it and plus they might not help me out since it's not under warranty to have seats swapped...-___-
Old Jul 28, 2003
wonderz's Avatar
do u know how much is the SCS Service Connector? and where i can get it? 'cause if its decentable(sp?) price, i might just go get one.
well, i gonna try again tomorrow or something when the sun is still out so i can actually see. btw what did you use to plug into the connector?
mrohitredd
Apr 15, 2015 08:13 PM
FlippedOut
Feb 11, 2003 06:27 PM
Jotosuds
Detailing
Nov 2, 2002 06:31 PM
