Swaybar or Strutbar?
--< GripSpeed Member >--
Hey wassupe everyone..finally saved up enough money to get either a swaybar or a strutbar...which one do u think i should get first and why?
Neuspeed strut bar...
Why? You have an 01 LX.
I believe you need to drill holes and get the endlinks. In short, it's more work but worth more than the strut bar. HUGE difference since you don't even have a stock sway bar.
Endlink pics.... steps 3 & 4 / holes step 5 (check if you have them)
FYI the following models do not need any special stuff:
01+ EX
02+ LX
Why? They already come with stock 12-13mm rear sway bars....so the rsx is obviously a bolt-on. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Here's my old review
-ak
01+ EX
02+ LX
-ak
oooooh...sorry lil misunderstanding..when i was sayin swaybar...i meant the progress sway bar...iono if i still need to drill for that one or not..hoepfully not...lol
Quote
[hr]Originally posted by: iceman
oooooh...sorry lil misunderstanding..when i was sayin swaybar...i meant the progress sway bar...iono if i still need to drill for that one or not..hoepfully not...lol[hr]
The Standard One
some people have complained about the endlink breaking off with a 22mm sway bar. but then he was auto-crossing... i personally would just go with the rsx 19mm sway bar(its only like $50 used).
if its between strutbar and progress sway bar, i would go with neuspeed strut bar seeing how its cheaper and does less possible damage.
Quote
[hr]Originally posted by: VNlilMAN
if its between strutbar and progress sway bar, i would go with neuspeed strut bar seeing how its cheaper and does less possible damage.[hr]
I would definatley say go with the sway bar. The only thing is for your car, you will have to buy a kit that makes it fit onto the 01 lx. i think it costs another 100+ dollars for that. but in the end the sway bar is by far one of the best suspension mods
The Standard One
oh.. you have an 01 lx.. progress has endlinks with mounts for $180 or so.. but ya get that with the progress sway bar and comes out to what $400 or so.. rather get the strut bar in that case..
anyone know how much the mounts are from like honda or acura?
Werd total price should be about 450. What I would recomend is neuspeed upper strut brace, and just go with dc rear tie bar it will help a lil with ur body roll, not as much as a sway bar would, but it would help a lil if u don't want to spend 4 somthing [IMG]i/expressions/face-icon-small-wink.gif[/IMG] or get a rsx sway bar and drill holes and so on and so on. Thank god I got the 2k2 lx so I don't have that problem.... Oh and if u do want to go big just get a jdm dc5 type-r sway bar. I just ordered mine tee-hee
Quote
dc5 type-r sway bar is 22mm as well.. which brings back the problem with endlinks and mounts for his 01 lx.[hr]
Quote
[hr]and just go with dc rear tie bar it will help a lil with ur body roll[hr]
hey iceman, im in the same position as you! hahaa i have 01 lx so id have to drill holes n stuff
so iono if ima go through the trouble-but if you do decide to do it, let me kno how it turns out
so iono if ima go through the trouble-but if you do decide to do it, let me kno how it turns out Joined: May 2002
Quote
[hr]Originally posted by: NytRyder2k2
if im correct the tie bar doesnt do anything as far as handling. its just support if u get a bigger sway bar[hr]
Quote
Quote
[hr]Originally posted by: ak
NytRyder is right. Lower tie bars just support the frame.... you can't feel them.[hr]
Quote
Quote
Hey wassup...thanx for everyones feed back...i think wut imma do is get a strutbar first...and then maybe just maybe later on down the line...i just might drill holes so i can put a swaybar on...seein how my warranty is arleady gone...lol
uhmm well, with the way u drive, i would suggest the strut bar first. It'll tighten your front end since u're always making those fast moves on the fwy. The sway bar would be a good addition afterwards. it's a great susp. mod, and it'll keep ur *** sticking to the ground.
mphole
North Cali
Aug 22, 2003 01:29 AM
txtadik
29
Mar 28, 2003 09:58 PM
WannaBFast
Dec 19, 2002 09:51 AM
