Smog Check ;)
Old Apr 24, 2007
W1LLY_G's Avatar
Smog Check ;)
I need everyones help, I been driving arround with after market headers for the past 2 years, well my registration was due in January, I need to do smog check but it wont pass cause of headers, Does anyone know where i can take it *wink* *wink* so they can help pass all emmision regulations,
please pm me.
Thanks in advance!
Old Apr 26, 2007
sl33pyriceboi's Avatar
Re: Smog Check ;)
i suggest you ask ppl to PM you.
because no one is stupid enough to post it up here....the shop would totally be vulnerable to the law officials
Old Apr 26, 2007
fidencio74's Avatar
fidencio74 is an unknown quantity at this point
Re: Smog Check ;)
please pm me.
Thanks in advance!
Try to get the OEM one. They're like 20 bucks. What header du you have?
Old Jun 14, 2008
lewal's Avatar
lewal has a spectacular aura aboutlewal has a spectacular aura aboutlewal has a spectacular aura about
Re: Smog Check ;)
Sorry to bump an old thread, but I just got a smog check requirement with my registration and was wondering if anyone could PM me of any shop they use that could help.
Thanks in advance.
Old Jun 14, 2008
qijian's Avatar
Re: Smog Check ;)
slappin on a OEM one doesnt take that long and its easy to pass check.
Old Jun 15, 2008
kcari's Avatar
Re: Smog Check ;)
will my greddy sp2 pass smog?
Old Jun 15, 2008
mrtrinh's Avatar
mrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of light
Re: Smog Check ;)
^yes why wouldn't it? unless you deleted your cat or have a header
Old Jun 17, 2008
lewal's Avatar
Re: Smog Check ;)
well, i'm not so much concerned about the exhaust. My CEL intermittenly comes on, and I believe it's somehow due to my remote start.
The codes were for cylinder(s) misfiring, but after troubleshooting it myself and bringing it to the Dealership (twice), no problems could be found.
Since my gas mileage remains 31mpg and the car runs fine, and because each trip to the Dealership cost $175+, I've simply learned to ignore it. However, I heard if my CEL comes on, the shop may fail me solely on the visual.
So let me know people, send a PM my way.
Old Jun 17, 2008
TRIZ's Avatar
Re: Smog Check ;)
Pull the bulb, or cover it up with electrical tape- take the cluster out and apart to do this. Or if you dont wanna take the cluster apart, you can dig up the wiring diagrams for the two connectors and remove the wire.
I'd also suggest removing your remote start to aid in troubleshooting.
...and I'm not sure how a cylinder misfire code could pop up from a remote start... i'm thinking injector, plug, timing, etc...
Old Jun 18, 2008
lewal's Avatar
Re: Smog Check ;)
yeah, i'm not sure either, but that's all I can think of. I replaced my spark plugs already and switched fuel injector positions (to see if the cylinder misfiring codes would change in correlation with the switching of "good" injector(s) with the potentially bad injector(s), but that wasn't the case).
I guess I can just reset the CEL and go in, and switch back to the OEM exhaust, although I've heard the 5zigen Fireball axelback will pass SMOG.
It's not the so much the work that annoys me, as it is the fact that all this seems pointless. Especially when I see cars spitting out blue smoke when they accelerate and I know my car is fine.
Thanks for the input, and I'll gladly take any suggestions from people of places to go =)
HX
Dec 28, 2001 10:04 AM
Cypher
Dec 21, 2001 09:50 PM
Micks2K1
Dec 6, 2001 07:09 PM
NightKids2
Nov 28, 2001 01:42 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
