FIXED AC in 100 degree weather = satisfied lil man
Old Jul 17, 2006
VNlilMAN's Avatar
The Standard One
It was working fine the last time i drove it and today i tried using it and it doesnt work. it just blows hot air as if the heater were on. when i turn the ac on, i dont hear the ac [compressor?] go on.
any ideas?
anyone know a good mechanic.(that list above is mainly for fixing up your car) i just need a good place that'll fix my car.
this **** s*cks.. i use my car for work too
Old Jul 17, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
pm drivetofast.
welcome to the world of no a/c. two summers and counting.
Old Jul 18, 2006
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
Originally Posted by aznboysrfr
pm drivetofast.
wow! your still here, I wouldve thought you blew your motor by now..
Old Jul 18, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
nah. motor is running strong [check sig]. 11 months and counting for that ...
Old Jul 18, 2006
HondaLuver's Avatar
Its a celebration bitches!
haha, yup 2 summers strong! hehe
Old Jul 18, 2006
mr_fobster's Avatar
^^ time for a new compressor
Old Jul 18, 2006
KaOtIcCiViC's Avatar
KaOtIcCiViC is an unknown quantity at this point
Hey David, I just joined the club earlier this month.
I think my situation was worse though when I found out my A/C went out.
I was in passing Bakersfield going to Las Vegas and the $hit died out on me. You could only imagine how much fun that was!!!
The problem with mine is that it works fine (cold air blows out), but after a while it starts making a noise like something is about to blow up.
I was doing 65-70mph and I felt the car accelerate and then decelerate. I had recharged the A/C myself with one of those cans from Kragen's.
Any help on what the problem is???? I would do it myself but I don't want to fawk it up. I plan on going to Honda only because I just wouldn't trust anybody else.
Old Jul 18, 2006
djmota's Avatar
mine went out a few months back. I trouble shot it and found out that when the refridgerant pressure drops below a certain point a switch cuts the power to the ac compressor clutch so it doesn't turn on. This usually happens because of a leak somewhere. I tried charging it myself and quickly found out that i have a bad hi pressure hose. No ac till i swap.
I wouldn't take it to honda. I would take it to a dedicated ac place. honda will rape you.
Old Jul 18, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^ might want to check all your belts and/or pulleys to see if they're in working condition.
vn man: your freon probably all leaked out.
Old Jul 18, 2006
Actually my other option would be to take it to a shop where they specialize on A/C.
I would troubleshoot it myself, but I don't have the confidence to fix it. My car runs smooth...no problems at all, it's just the A/C that acts up.
Thanks!
Where you telling that to me or djmota????
Thanks!
Old Jul 18, 2006
jHIbZ's Avatar
jHIbZ is an unknown quantity at this point
i have a ac problem too. about 2 months ago my ac died... but in my case ac clutch poped out that's why i need a compressor assembly to be replaced.. anybody knows somone who would find a used compressor and install it for me? cheapest i found is 150 labor and whatever the used compressor costs (100-130). you think someone would do it cheaper and dont have to bring the car 50 miles away? thanks.
Old Jul 18, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
Thanks!
you.
Old Jul 18, 2006
Cool, thanks. I'm sure everthing is okay though, because then I would have other issues, right????
Old Jul 18, 2006
7thGenerasianCivic's Avatar
how do you guys survive? It's FAJUCKING HOT!!!
Old Jul 18, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
well if your car is decelerating then yeah ... I would say something seems wrong ...
Old Jul 18, 2006
VNlilMAN's Avatar
The Standard One
I just saw that at autozone, did it help at all? did you flush it out and put it in or did you just put it in? do you have the guage for it?
djmota, how did you find out it was the high pressure hose?(which one is high/low anyway? bigger line=high and smaller line=low?) cant you just change the hose and your good to go?
also i saw this product that supposidly seals any leaks(its made for the AC), what do you guys think?
www.efproducts.com
kind of iffy about doing this myself but i also dont want to get raped by a shop.
Old Jul 18, 2006
VTECTypeR's Avatar
Recharging it is a piece of cake man. Anyone can do it. you just plug the hose in the low pressure line on the AC line. Most kits come with a gauge and it tells you if you need to fill it or not
Old Jul 19, 2006
VNlilMAN's Avatar
The Standard One
low pressure is the one closer to the strut right and not the one closer to the front bumper?
Anyone have the lines for it so that i can just buy the can?
Old Jul 19, 2006
The low pressure on mine was the pipe that was closer to the bumper. The caps have an "H" or an "L" on the top.
As far as me when I did mine, I didn't flush it out, all I did was check the pressure (it was really low) and then decided to buy the rechargable cans and just refill. I don't know if that fawked it up.
I need to check that, because if that's the case then there's a lot of money that I'm going to spend than what I anticipated. Any shops around that you know of in the 626/909 area?
Thanks!
Old Jul 19, 2006
VNlilMAN's Avatar
The Standard One
wait so your ac wasnt working so you recharged it with the can and now it has that accel/deccel/noise problem?
Old Jul 19, 2006
djmota's Avatar
www.efproducts.com
Well I Charged the system and the compressor started working then in I saw a nice white cloud coming from the back of the engine. I still have the charging hose, you can borrow it if you want, but your all the way in LA Let me know.
Old Jul 19, 2006
Naw dude, the A/C was working fine. It just needed a recharge. So I went to go buy 2 of those cans to recharge the A/C on Saturday. Sunday I was heading to Vegas and I decided to turn on the A/C and I felt the car accelerating and decelerating and then I started to hear a noise of something rattling and so I just turned it off.
I'm just afraid of how much this is going to run me to get it fixed.
Old Jul 19, 2006
djmota's Avatar
could be a bad compressor clutch or a bad compressor.
Old Jul 19, 2006
Maybe. That could explain why the A/C makes my car accelerate and decelerate. I mean, our Civics don't have the power of an NSX, but you could tell how all the power goes down when you turn on the A/C.
Old Jul 19, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
a/c drains a ridiculous amount of power.
someone on ephatch dyno'ed their stock ep3 with and w/o a/c ... he lost 20 whp. yes, 20.
not sure how much it drains from the d17's ... I dont' think it would be quite 20 though ...
Old Jul 19, 2006
VNlilMAN's Avatar
The Standard One
cool beans.. djmota, what city are you in? probably too far. think i might just buy the can then. hopefully i wont f*ck anything up.
i noticed the guages they sell measure by psi... how do i know how much to put in?
Old Jul 19, 2006
VTECTypeR's Avatar
Just buy the gauge. Check if its at the right pressure. If everything seems normal return it. Thats what I did when I found out I dont need to recharge it
Old Jul 20, 2006
VNlilMAN's Avatar
The Standard One
**** so i do have a leak.. its on the low side pipe.. about $35...
probably just take it to the shop...
after this, my car is going back to stock.
Old Jul 20, 2006
Yeah same here dude, I'm thinking about getting another car.
Maybe a TL or a TSX.
Old Jul 26, 2006
VNlilMAN's Avatar
The Standard One
after a week with no AC in 100 degree heat and $160, i finally got it fixed... =D
