help wit koni struts + replacing a driver side axle
hello. has anyone in cali installed koni yellows on his civic and would like to install the fronts for me? i know theres drilling n cutting involved and i dont want to do it myself. i also need a driver side axle to be replaced. i have all the parts n im not looking for a freebie. im willing to pay for the labor no problem. please let me know.
Originally Posted by MBison
just did. they dont do installs..
basterds! they use to, hmmmmm i know there is shops out there that will do it, just have to find one. also one that is a koni authorized shop is allways better.
Konis need to be cut and drilled so it fit? Why? Is it like the 01-02 strut botls being 14mm and 03-05 being 16mm or is there something else? Because i had to do that will my tokico blues, but im replacing them with Kon Yellows also.
^yea they need to be somehow modified. the bottom of the housing has to have a hole drilled in it n thats where a bolt will go that holds the strut in place wit the housing.
help me wit this vinnie
hahaha sorry i didnt even want to this for myself.
here is the full DIY
http://hondatuningmagazine.com/tech/0205ht_suspension/
i did it once, but i never like how the koni's felt and i actuall blew out the rear shocks because the coilover i has were very cheap. So replaced the entire suspension with RSX suspension then TIEN!
It's really not hard at all but it will require a little muscle to cut the lid of the OEM shock (get's used as a sleeve for the new shocks)
If you have some one do it i would say it should be more than $75-130 just cuz it takes a while to cut them.
Oh yeah I LOVE MY TEINs!
Drivetofast (Josh) may be able to help you out. Haven't seen or heard from him in a while but he did mine almost two years ago. They still ride fine and it only took him two or so hours to install.
ej8
Apr 13, 2015 06:36 PM
tattedlariat
Apr 12, 2015 07:55 PM
for a nice guy that could help me out wit this
