An automatic stalling!?!?!?
Old Sep 12, 2005
Nodnero's Avatar
So my homeboi Abe has a problem. Besides having an automatic transmission, his car is stalling on him when he is stopping at lights. Not 24/7, but its happened 3 times now. I figure its: A) Fuel Filter B) Injectors or C) Fuel Pump.
He says he also puts 91 in the tank every once in a while, so Im not sure if its the spark plugs, but I would doubt it. What do you guys think that it is?!?!? BTW, he has 70ish K miles on it, and has never been in for service.
Old Sep 12, 2005
dj02's Avatar
fule pump is out or the relay! i got 20 bucks says thats the problem. and wtf would he put 91 in for.
Old Sep 12, 2005
blue_dlb's Avatar
blue_dlb is an unknown quantity at this point
Does the 7th gen have some kind of idle air control valve?? May wanna check on something similar to that because it only shutdown at complete stop. May also be the o2 sensor.
Old Sep 12, 2005
AlpineCivic's Avatar
Alternator? My last car used to shut down on my when I had the system cranked up and the charging system couldnt keep up. Maybe something electrical?
Old Sep 12, 2005
Nodnero's Avatar
Well, he won $20 becuase he said he knew somebody would put a comment about using 91. Get over it Vinnie! And yeah, Im with you about the Fuel pump.
The alternator seems like an interesting choice tho as well. Abe was running the 2 12" Solobaric L7s and pushing them like none other for the longest time. He says hes going to get it diagnosed tomorrow, Im about to fix his rear strut in about 15 minutes. I'll give him that idea.
Old Sep 12, 2005
spoonEM's Avatar
omgwtfbbq mod.
Chase....make sure hes not out of blinker fluid too. Thats been quite notorious for causing problems.
Also....youre three choices would have been top on my priority list too. Although.....check the spark plugs anyways. Also...the alternator is a definate possibility seeing as to how i destroyed my last one with the same setup. If none of these work....just tell him to go ahead and get a replacement K20 and just stick it in there. Im about 100% sure that will fix all his problems.....including almost losing to a 5spd LX!
Old Sep 12, 2005
PennyKnotOff's Avatar
I'm gonna put my money on the alternator
Old Sep 12, 2005
dru106's Avatar
ThE CoRRupToR
Hmmm..... was he able to start it right after he stalled or did he need a jump?? If he needed a jump start than for sure its the Altenator if not im not sure....
Old Sep 12, 2005
dj02's Avatar
wait for the cel and if there is one then im 100% sure its the fule pump or relay. and abe don't use 91!! :P
Old Sep 12, 2005
Em2Guy's Avatar
Em2Guy is an unknown quantity at this point
Check Your Iac Valve
Old Sep 12, 2005
Yup that and clean the tb and reset the ecu. Could just be something sticking. But iac controls idle
Old Sep 13, 2005
dalaw's Avatar
Bone Stock!
My old camry used to stall once in a while idling with the a/c running
Old Sep 13, 2005
JCiv03's Avatar
I think it might be the alternator... This is from personal experience (not my car though).
Old Sep 13, 2005
ragingSPAM's Avatar
I just burnt my tongue
alternator?...doubt it if he can restart it there....if its bogging and dropping low in rpms while in gear in the auto than its prolly his injectors because they're clogged so the fuel doesnt get to the cylinder until enough pressure builds up to force spray it into the cylinders which causes too much fuel to burn at once and it floods the cylinders with too much fuel causing it to bog low...it gets to run too rich when that happens...also tell him to check and clean his throttle plate...here is how
1) take off the intake so the throttle is visible from the inside
2) get carb cleaner and a rag
3) make sure the car is off than open the throttle plate
4) get the carb cleaner and spray it on the rag and on the throttle plate
5) wipe clean the throttle plate and area around it with the carb cleaner/rag
6) put intake back on and restart the car and try too see if it does it
also buy some fuel injector cleaner from autozone and put it in your gas tank...i recommend the amsoil P.I. which isnt availible at stores or u can use the bars leaks products....check the fuel filter too
Old Sep 13, 2005
scrimp's Avatar
scrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of light
Where is the IAC valve at?
Old Sep 13, 2005
that part bolted to the left of the tb. with the intake off, you can see a small air port and the iac should be attached to the side.
Old Sep 15, 2005
PaCiFiKbAllA's Avatar
PaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond repute
i had the same problem...and it was the TCS sensor on the Throttle Body...supposedly "they go out sometimes" according to the dealer...it use to happen to me before, my car would stutter, drop really low rpms, and then die out...i always use to turn the a/c on just before i stop so it could boost up the rpms a little...hahaha...don't say u guys never done that before!
Old Sep 15, 2005
djmota's Avatar
my bet is the iac valve. its on the side of the throttle body held on with 4 screws. Sometimes they get stuck closed or open with carbon. some carb cleaner on it usually fixes the problem. If he gets a cel. I have a reader and can scan it for him.
Old Sep 15, 2005
ragingSPAM's Avatar
iac valve along with a derrrty throttlebody/throttle plate would be a cause for stalling
danace99
Oct 17, 2015 02:51 PM
cferry7
Oct 3, 2015 04:33 PM
General DIY
Sep 25, 2015 08:02 PM
2.0.0.2
Sep 14, 2015 06:38 PM
thaler4cuse
Sep 7, 2015 08:25 PM
