FS: Amps new in box
FS: Amps new in box
X1.800.4 - $300 shipped
Storm Class AB 4-channel amplifier
100x4 @ 4 ohms
200x4 @ 2 ohms
400x2 @ 4 ohms
24dB variable x-over from 50Hz-250Hz
Dual Power Supplies
Pass Thru outputs
this amp has power to spare!! fully adjustable crossovers, 4 ga power and ground inputs, looks awesome and outperforms most amps at this price
just got two 300.2's and a 400.2 also
pics up tommorrow
$75 each for the 300.2's (used) and $150 for the 400.2 (new)
all trades and offers in the area will be considered
3 pictured but only one 800.4 for sale....well money talks so we will see what the interest is.
here it is in the spare tire area.
edit..the logo is acctually at the top......i took mine apart and flipped the cover plate and the logo so that i could have all the power and speaker connections on the right side.....
100x4 @ 4 ohms
200x4 @ 2 ohms
400x2 @ 4 ohms
Dual Power Supplies
Pass Thru outputs
pics up tommorrow
all amps used a plug for power, remote and ground. when i worked at LA we charged $5 for each plug...sometimes $0 if we were having a good day. these amps will need the plugs...
Lightning Audio Strike 400.2
$150
3 of the feet were bent in shipping...
RMS Power at 4 Ohms 100 W x 2
RMS Power at 2 Ohms 200 W x 2
RMS Power at 4 ohms mono 400 W x 1
Low - Pass Frequency 50 Hz - 250 Hz
High - Pass Frequency 50 Hz - 250 Hz
Signal to Noise Ratio 90 dB
Bass Boost Frequency 50 Hz
Width 10.4 in.
Height 2.2 in.
Depth 12 in
Lightning Audio S2.300
$75 each
amps were used in show car...the power on light doesnt work..it was wired to be turned on by a switch for photo shoots....those are the wires coming from the top.
RMS Power at 4 Ohms 75 W x 2
RMS Power at 2 Ohms 150 W x 2
RMS Power at 4 Ohms Mono 300 x 1
Low - Pass Frequency 50 Hz - 400 Hz
High - Pass Frequency 50 Hz - 400 Hz
$150
Width 10.4 in.
Height 2.2 in.
Depth 12 in
$75 each
h4ldol
Apr 24, 2017 08:16 PM
Raiool
Oct 1, 2015 10:42 AM
Hutch1051
Sep 29, 2015 09:20 AM
