Back.....
The LA Clipper
Originally Posted by VTECHGRL
in response to this....
the subs aren't flat, the older ones are, when a system is running at high listening levels the voltage will drop dramatically, that is why I'm going to get a bat cap ... the usamps amp isn't going to be ran directly from the primary battery but isolated off of it and the batcap as well. The amp also has regulated power supplies and i'll be adding those things just to be safe. .. the batcap has the fastest energy transfer so it can be used as a standalone accessory power source. The enclosure we will be attempting to create will be highly efficient which means we don't NEED 2400+wrms (the amp was bench tested at over 3000w @ 14.4v <- normal vehicle electrical system voltage) I can use just one channel and run off 1000w
http://www.edesignaudio.com/kv2.htm
hows that....
... http://www.edesignaudio.com/kv2.htm
hows that....
Looks like I need to build a ported box for my subs...this was my last one 9or two i should say), but it was toooo loud for me...so my subs are sealed again
I think you would slaughter me with my current set-up...but ported I dunno.
The LA Clipper
Originally Posted by VNlilMAN
too loud? wtf? louder than your 4 shivas??
btw hi jonda
btw hi jonda
I would rate it like this in terms of loudness:
1. 2 ported IDMax
2. 4 Shiva Isobaric
3. 4 Shiva sealed
4. 2 Max sealed (current set-up)
I COULD HAVE THE VENTED BOX BUILT IN 30 MIN....couple of mesurements, few cuts, bradnailer, and some liqued nails...and youll be bumbing in no time girl,....all that bas is cool and ****.. but most of the time i ride with it way down....only when its time to clown...will they drown... in my bass wave...haha...im a poet and didnt even know it..
Guest
Posts: n/a
hi Dave!!! missed ya homie!!
and Vin, dont make me come kick your a$$.... (hehe-xoxo)
Guest
Posts: n/a
Herbie1964
15
Jul 2, 2009 04:33 PM
