need to know some cheap installation places
Old Jun 2, 2004
gsr-t's Avatar
gsr-t is an unknown quantity at this point
I want to install 22mm sway bar, guages, rotors and pads and was wondering if any of you know of any places that does install work for low prices? I am located in the el monte, rosemead area. Thanks.
Old Jun 2, 2004
VNlilMAN's Avatar
The Standard One
the sway bar i would just DIY, its real easy(unless if your car doesnt have a stock one that is).
pads are easy but not sure about rotors. i'm sure any brake shop can do it for under $30.
guages, i think depends what kind
Old Jun 2, 2004
Nodnero's Avatar
Yeah, DIY the sway bar and you can probably do the rotors and pads. Im not sure whether or not there is a DIY on it here on 7thgen. As far as gauges, you might be able to do that yourself dependent upon which one it is and how willing you are to learn about your car.
Old Jun 2, 2004
AlpineCivic's Avatar
The pads and rotors are easy to do. I did my AEM Big Rotor kit myself its not that hard.
1. Take your wheel off
2. Take out the two bolts holding in the stock caliper (thats the hardest part cause their on tight)
3. Slide your rotor off
4.Brakes are easy to change they just slide off and on from the caliper.
5. Put everthing back in reverse.
Old Jun 2, 2004
if not contact "dj02" he does good work at a good price.
Old Jun 2, 2004
born2xLr8's Avatar
Anyone think a collision repair shop can install lowering springs while they're at it? My car is getting repaired and I was thinking, "they might as well stick my neuspeeds on while they're working on it."
Old Jun 2, 2004
blue_dlb's Avatar
blue_dlb is an unknown quantity at this point
03-04 EX cluster conversion installer right here for all you DX and VP.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
mistermenphis22
Apr 3, 2016 08:06 AM
importable
Nov 16, 2001 09:58 AM
aZnVoYCe
Nov 7, 2001 05:54 PM
wsking77
Aug 29, 2001 05:34 PM
