Koni Installs
Old Sep 22, 2003
InOvAtStyL's Avatar
Never Too Wide, Never Too Extreme
InOvAtStyL is on a distinguished road
Koni Installs
For those of you who have konis installed on your car, where'd you go to get them installed at. I have my rears on already, but i need someplace to install the fronts. I've taken them to 3 places, and all 3 places didn't want to do it for me cause they didn't want to risk messin it up when they cut the stock shock sleeve. I need to install my front shocks ASAP cause I need to be in SD for importfest next month, but I won't be able to take it in to change my shocks till my car comes outta JT in about 2 weeks. Please refer me to a place that will install them and what the cost would be. Thanks in advance.
Old Sep 22, 2003
dj02's Avatar
thats hard and its not going to be cheap ur looking around 200-300 to get them done and u have to try really BIG shop's. or allways do it ur self there is a diy for them. or like in the diy u can take it to ebiach and theyll do them probly for like 400 loll
Old Sep 22, 2003
VNlilMAN's Avatar
The Standard One
its not that hard is it? just cut it using a pipe cutter, drill a hole at the bottom and attach the konis to it. i know easier said than done but it still shouldnt be too hard. i know andrew(civichx) did it with his dad
Old Sep 22, 2003
InOvAtStyL's Avatar
200-300 or even 400?!?!?!........I was lookin around $40. I got my rears installed for 40. Tiens don't even cost 200-300 for intall. max for tiens go for around 120 installed all around. You might be quoting me for the install and the part. Sorry for not makin myself clear but I already got the shocks, I just need install.
Old Sep 22, 2003
dj02's Avatar
no im quoteing for install only there is alot of work that needs to be done just look at the diy, and about it being hard david, it is and isnt...... if u have ALL the right tools then ofcorse it's not going to be hard but if u dont and plan to do this in ur garage then good luck and ill see u in 2 day's. rember its not just about ok ill cut it open, drill a hole and fill it back up and tada! takes a lil more and im probly over quoteing on how much it will be but at least be ready to spend 200 on install. just look at the pics for install
Old Sep 22, 2003
PunkingCivic's Avatar
I need TP for my bunghole
Click here - yahoo yellow pages
Old Sep 22, 2003
sffree's Avatar
sffree is an unknown quantity at this point
If the San Fernando Valley (LA) is close to ya, go to Tripoint Engineering in Canoga Park. They're Koni distributors and authorized koni re-build center. They are VERY experienced with gutting the original shocks in the fronts with the Koni replacements. Their prices are good too. But as far as install, yea, be prepared to spend a little more than you want cuz it's VERY labor intensive. good luck
Old Sep 22, 2003
etrnlderek's Avatar
etrnlderek is an unknown quantity at this point
Ya Tri Point is good and Tony Fusch does it to. He did it for 200 and less. You can get his number from Darkside. He did Elikas shocks that i traded with her recently. You should ask her about it. Her 7thgen name is sugarplum.
Old Sep 22, 2003
InOvAtStyL's Avatar
thanks for the help guys. I'll give tripoint a call. I just need to wait for my car to come outta the shop.
Old Sep 22, 2003
CivicHX01's Avatar
yea i DIYed mine... its pretty simple to do it and there is a some margin for error... i used a hacksaw tho so it took me quite awhile... it would be a lot easier if u have a pipe cutter for cutting the shocks...
all you have to do is drill the bottom
pour out the fluid
cut the shock
take out the cartridge
insert the koni
screw the bottom
and that's it your done!!
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
