Oil Change?
Old Sep 3, 2003
JOO's Avatar
JOO
JOO is an unknown quantity at this point
Oil Change?
FUC!K!! i just ATTEMPTED to do my oil change cuz the shop that i normally goto said that once i add the Lip kit that itll damage the kit and they said to start doing it by myself.
I ****en used a goddamn adjustable wrench and i stripped it. so wtf do i do?? mother****ers at the previous shop tightened too god damn much. well. I guess ill just goto the dealer and tell them to give me a replacement and go back to the shop and yell at them for ****en tightening my ****en oil bolt too ****en much. well. ****. im pissed. anybody do their own oil changes?? plz help me
Old Sep 3, 2003
dj02's Avatar
joo how the **** u do that and y didn't u use a socketwrench I do my oil change all the time. see if u can get a socket in there or else drill the nut out
Old Sep 3, 2003
SkiLLzSter's Avatar
illest ma f*cken member
looks like you got the oem lip kit...that wouldn't interfere with the lifts...i use to do it myself until i dropped it then i used some homemade ramps i made from 2x4s but still was too much trouble so i just go to the dealership and pay 21.95 to change it...
Old Sep 3, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
heh ... adjustable wrenches strip EVERYTHING
Old Sep 3, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
You could try HAMMERING a small socket (13mm?) into the stripped bolt. Sort of like what people do with stripped wheel locks...
I stopped changing the oil in my civic after oil from the filter nearly burned my arm. lol!
Lesson learned
Old Sep 3, 2003
DizWikedCivic's Avatar
have you try using vice grip
Old Sep 3, 2003
Nodnero's Avatar
Yeah, Vise grip that bad boy. If that dont work, get a massive cresent wrench like what plumbers use. Tighten that ish so hard that it doesnt move and it'll loosen right up.
Old Sep 4, 2003
CapYoda's Avatar
Escaped Convict
er.. does that adjustable wrench have enough leverage??
you shouldn't be using that... you might not have enough torque to get that bolt going.
although it shouldn't be torqued very much..
Old Sep 4, 2003
ak's Avatar
ak
Retired Mod
This thread might help...
http://www.7thgencivic.com/forums/sh...hreadid=112354
Old Sep 4, 2003
Handsonme's Avatar
awwww. =(
Do you just jack the car up?
Cuz my car gets lifted up, then u have more control while standing over what u do.
Old Sep 4, 2003
CivicHX01's Avatar
Lesson learned
haha thats why you change your oil after your car has cooled down a bit (if the car is too cold though the oil filter is really hard to get off)
and JOO, what are you doing using an adjustable wrench?! those things were not meant for taking out tight bolts... they're meant for taking out a lot of different size bolts to save time (so you don't have to keep finding the right size)
go buy yourself a socket wrench set in mm (everything on our car is in mm), good investment...
Old Sep 4, 2003
VNlilMAN's Avatar
The Standard One
you guys need to find better shops... the one i goto has a nice lift. i just drive in the garage, they put the 4 adjustable arms where the jacking points are and lift my car up. so ya dont have to worry about going over bumps or ramps. if you cant clear the 4 adjustable arms(which are pretty small) they'll even jack up the car by hand. best of all they only charge $10
Old Sep 4, 2003
Nodnero's Avatar
Does that include oil and filter?
Old Sep 4, 2003
snoopbag's Avatar
snoopbag is an unknown quantity at this point
Take it back to te shop that overtighten it in the first place and tell them that they stripped it and see what they say. They can always put your car on jackstands to get the oil plug off. I used to go to Jiffylube or Grease Monkey because they have in ground pit that don't mess with your car.
Old Sep 4, 2003
VNlilMAN's Avatar
The Standard One
ya it includes everything. oil, filt, tax, disposing fee, whatever else that applies...
Old Sep 4, 2003
dj02's Avatar
and this is where in the valley?
Old Sep 4, 2003
VNlilMAN's Avatar
The Standard One
noho on lankershim and like victory. i'll get the name of the place when i get my next oil change...
i used to goto purfect(they have like 3 locations in sfv) and they were only like $10 too but their ****s when it comes to lowered cars
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
BootyDo
May 7, 2015 04:46 PM
SoNiCcIvIc
Mar 11, 2002 03:37 PM
AnotherDopeStyle
Jan 5, 2002 03:10 PM
