Malfunction light
Malfunction light
Hey guys, I was driving home tonight and then all of the sudden, when I took off from a light, my engine kinda shut off at 4K rpms, so I shift to 2nd and still the same thing. It only did that for about 10 mins or so. Does anyone know what it could be. I looked at the sensor on my intake and it is kinda loose, but I don't know if that would cause the 4K rpm thing. Please help!!!
Well I shouldn't have talked so much **** cuz I threw thw same code today. Looks like there is a ton of wiring to be tested, but check oil levels too cuz low oil will keep it from engaging.
Check oil level first... without my vafc my vtec would not engage if it was low(like to the bottom mark on my dipstick). Next make sure the corrector is on there good, unplug and replug it. Then...
The screen for the solenoid might need cleaning(it can get mucky). If it gets clogged it doesnt let enough oil/pressure into the pins to engage vtec properly.
-unplug vtec wire
-unbolt solenoid(make sure car is cool and a rag to catch any oil...)
-clean filter screen with something thats safe for the rubber gasket attched to the screen material.
-re install reverse of removal
-reset ecu by pulling clock/backup fuse underhood for 30 sec.
-drive
(I am not respsonsible for anyone f***'n up their cars...!)
Peace
-unplug vtec wire
-drive
Peace
Originally Posted by Rufus
I have already done everything on that list.
Peace
Yeah, I'm burning oil so there's a leak somewhere. Might be oil pressure. At least now I now what it feels like to drive a non-vtec d17. SHI*TTY!!!!
-Deck not seating and sealing properly(head gasket, but then you'd prolly be burning coolant too...)
-Valve guides/seats leaking
Those are the only ones I can think of that would allow oil into the combustion chamber assuming its from the head being off... and not bottom end(rings etc.)
Isnt it the same as driving under 5200rpm? Or am I off, the vtec comes online sooner?
Peace
Yeah you're right on the seals. I'm sure that everything was followed to the "t" on head installation. My only thought would be valves. Rings were fine before fo I'm sure it's in the head. I'm not sure when Honda set Vtec to come on but in "safe" mode it won't allow over 4k period. On top of that if it does, vtec will not engage.
Peace
Hey man the same thing happened to me , go to discount auto parts and use there litle computer thing to test your car out, bc that was the same thing that happened to me (felt like my rev limiter kicked in at like 4000rpms) and i drove like that for about a week and before i new it my motor went...bye bye! Now I redid my ecu, new motor, turbo, interals, ive done it all it hits the street for the first time completely built next weekend
g4384063
Jun 1, 2015 07:59 PM
werdnahall
May 17, 2015 11:37 AM
tylerginevan
Apr 27, 2015 12:29 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
