Autocross STF class em2 or dc5?
Old May 30, 2013
EcoRacerD17's Avatar
EcoRacerD17 is an unknown quantity at this point
Hello everyone!
So I'm in an '04 em2 ex which I'm currently selling to get a manual transmission car, but right now I have two choices for the Street Touring Fwd class in autocross within my budget, but I'm hoping for some advice from some who have experienced both a manual em2 and/or base RSX. (I'm not going for the Type S because the base RSX has usable torque)
So here's the factors that go into this...
In this class you're allowed...
-225 width tires (140 tread wear)
-Lightweight wheels
-Coilovers
-F&R sway bars
anything else will be marginal performance increases... (intake/exhaust, racing seats, etc...)
The differences between the cars...
A VP or LX em2 ~2400lbs.
A base RSX ~2700+lbs.
em2 - 115/127hp 106/115ft/lb
RSX - 160hp ~140ft/lb
Rsx has a slightly longer 2nd gear
Will the weight difference make up for the hp gain in the rsx?
Thanks for any advice, suggestions, and opinions!
Old May 30, 2013
Re: Autocross STF class em2 or dc5?
leeet me see...
you run SCCA and sometimes NASA (which I am unfamiliar with)
remember that the EX trans are shorter, so by going to VP/LX (which actually are not EM2, if memory serves me well) you might be loosing some acceleration, plus the 3->4 valve system (which is better than the LX type, which I owned before the current EX).
the RSX have the K series that in general responds better to the engine mods allowed in ST class. however, the base K-series was not as good as the RSX-typeS.
also, not completely sure if this is some weight distribution or chassis stiffness, but in stock form the RSX is more oversteer prone, which could scare in the slalom but a ton of fun at the autoX.
considering that you will get a worse pax, but the base of the car is better and responds better to mods, I would have choosen the RSX in your case. I bought mine and then started running, so my bond to the car was already done... and got 2 more miatas, so if I bought another car it would be either a 4WD or an older Honda instead, though (cheapest double wishbone you can get, what to not to like? )
Old May 31, 2013
Yea, really want to get competitive in SCCA autocross though, thanks for the info! Just curious do you recall how fast 2nd gear will go in the LX civic? A redline at about 62mph is what I'm looking for and the rsx seems to top out right around there from what I've seen.
Really might have to try for an RSX now though, especially the info regarding oversteer. And also, the pax for the 01-05 civic and the rsx (both base and Type-S) are the same. Right now people are running base Minis and the Mazda3 at nationals for the class, so I'd love to build a Honda that can hang with them!
Old Jun 1, 2013
not sure, will need to check the spec sheet...
oh, found in H-T (thanks, Matt )
http://honda-tech.com/showthread.php...d%26amp%3Bgear
Originally Posted by toyomatt84
EX 5M Gear Ratio
First 3.143
Second 1.870
Third 1.241
Fourth 0.970
Fifth 0.757
Reverse 3.231
Final Drive Axle Ratio 4.412
EX AUTO Gear Ratio
First 2.722
Second 1.469
Third 0.975
Fourth 0.674
Reverse 1.955
Final Drive Axle Ratio (:1) 4.067
HX 5M Gear Ratio
First 3.461
Second 1.750
Third 1.096
Fourth 0.857
Fifth 0.710
Reverse 3.231
Final Drive Axle Ratio 3.208
DX/LX 5M Gear Ratio
First 3.462
Second 1.870
Third 1.241
Fourth 0.970
Fifth 0.711
Reverse 3.231
Final Drive Axle Ratio 4.111
DX/LX AUTO Gear Ratio
First 2.722
Second 1.469
Third 0.975
Fourth 0.674
Reverse 1.955
Final Drive Axle Ratio 4.067
ah, found more info:
(thanks fleabag )
Originally Posted by fleabag
The gear ratios you have listed for the Civic HX are in fact not for the Civic HX but for the Honda Insight (2000-2006)!
Here are the gear ratios for the 2001-2005 Honda Civic HX 5-Speed Manual:
First 3.461
Second 1.750
Third 1.166
Fourth 0.857
Fifth 0.71
Reverse 3.23
Final Drive Axle Ratio 3.842
I got these numbers straight off the Honda website..
http://www.honda.com/newsandviews/ar...20010104001151
Old Jun 1, 2013
you can find the spec sheets for another years here too
http://honda-tech.com/showthread.php?t=2244923
Old Jun 1, 2013
here are the links:
Old Jun 1, 2013
here are the links:
Old Jun 4, 2013
Thanks for the links & info, been busy putting the numbers through the calculator the past few days!
Old Jun 4, 2013
g'lucky and keep enjoying autoX
deanaZoom
35
Sep 19, 2015 12:22 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
