Good Driver
Old Jun 23, 2005
o4exowner's Avatar
o4exowner has a little shameless behaviour in the past
Good Driver
I am posting this in the Track/Street/Strip area becasue i wanna hear from you guys who talk about a drivers race and all.
I just wanna know what makes a good driver and hear some tips from you guys such as luanching tips and if after the launch you just dump the clutch on the rest of the shifts, thanks a lot.
Old Jun 23, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
practice. go at like 3 in the morning on some street thats empty for the night. try taking off slowly, then see how you like it, then go a little faster. work on the shifting alot. turn of the car and practice the motion of shifting. if you don't want to wear the cables out then go to a junk car with a stick and do it. try not to shift too hard, meaning don't try to push the stick past where it can go. try not to halfway shift. don't drop the clutch at hi revs unless your trying to burn your clutch out. good luck. practice. thats what i did when i got the car. good luck
Old Jun 23, 2005
Michalo187's Avatar
Abortion Survivor
Yeah thats all you have to do dude practice like Brian O'Conner go to a empty stadium and top your car out at 140 and then go back to the store and get nawz for the big race. hahahaha practice thats all i can say you will figure everything out just fine
Old Jun 23, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
dumping the clutch in some cases will hurt acceleration. Launch, takes practice... many variables, such as tire pressure, clutch life, tire you have, and more.....
Old Jun 23, 2005
Michalo187's Avatar
Abortion Survivor
O yeah you also have to avoid tire hop very much that will kill you a launch has to be burning out but not to much and not dump or dragging your clutch just practice that and avoid tire hop and to much burn out
Old Jun 23, 2005
AJ Quick's Avatar
AJ Quick is an unknown quantity at this point
Old Jun 23, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
ES motor mounts for only $30 = no more wheel hop.
Old Jun 23, 2005
bgoetz's Avatar
bgoetz is an unknown quantity at this point
yep , but also =burnt out headlights every 8mos. for my car. But I will say for the money they are without a doubt the best mod you can buy
Old Jun 24, 2005
Michalo187's Avatar
Abortion Survivor
^^^^ Why burnt out headlights?
Old Jun 24, 2005
Vantage's Avatar
Vantage should not be trusted
If ur running big power, preload ur tranny by pulling e-brake then having the clutch out a bit so the car "sinks" then u wont blow CV shafts like u do with dropping the clutch. NEVER drop the clutch tho, very hard on everything, u want to release it slowly, my old car was 3 seconds. After the lights i would count down from 3 before i totally released the clutch and put the gas in WOT. This will be different in any car, becuase if i didnt do this i woulda spun all the way threw 1st. Also, work on ur shifting, this can really make or break a good run, and u can make up a lot of time if u can throw a good shift. and altho i never did it myself. U can always shift without the clutch for faster throws. just take foot off gas, ram that bitch into gear and right back on the gas. another trick that takes practice to get fast is, when shifting, pop ur car outa gear without the clutch, and just TAP the clutch to get it in gear. This will not hurt ur tranny, but it is an easier way to shift faster and keep ur rev's up. CAuse the second u push in the clutch u will lose rev's. Basically pratice, with some pointers is the best u can do.
Try to keep wheel hop to a minimum. As redline04 said, new mounts will work. u can also get a traction bar( dunno if they make them for 7th gen's yet) and that will help. Also, try to eliminate bogging by keeping the tires slipping, but not spinning( u will know ur doing it when u do it) this will keep ur RPM's high and not let u bog. feathering the gas will let u do this. dont be scared, ur RPM's wil jump up fast but they will usually stay around 6000 till your tires grip, u should feel when they grip, then the RPM's will start climbing as normal. Then keep ur foot down and away u go.
Old Jun 26, 2005
bgoetz's Avatar
My thought is that I have silverstars and the mounts add alot of vibration to the frame and eventually it breaks the filaments. I seem to be ok as long as I don't start the car with the lights already on (instant vibration to hot filaments)
Old Jun 28, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Those silver stars are junk if you ask me, overprices and don't even look that great, no offense to you bgoetz, I wanted to buy them for a while.
Old Jun 28, 2005
actualy, did you get the headlight wiring recall, I have a 01 and had it done a few weeks ago.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
