Good day for the old Civic
bgoetz has nowhere NEAR the modifications to his car that redline04 has.
What??? He has a DX..... that is a good amount of hp just the ex to dx difference. I have a clutch flywheel that do make you car faster (and yes a clutch does to because it is slightly lighter than stock thus reducing rotaitonal mass more). I have engine mount inserts that help me get it to the ground to launch better (and yes it helps alot). I have done some very minor weight reduction (no were near enough to offset hotrod though. The bigest thing that he had was the DRs
hey its possible to beat a subaru turbo. I beat the turbo outback subaru. I'm not sure if its turbo or not but I know its like 250 hp. Anyone heard of the outback? I raced one from a ditch about twice to 80 mph in the streets. The guy had about maybe 4-5 passangers in his car and was ****ing with me. I was alone. All his passangers were ******* me including the driver so I went for it. He thought my coffee can exhaust wasnt pulling ****. I downshifted to second so he downshifts and catches up, by third I sprayed on him and pulled deeply on him. He had to make a right cuz that was where he was going but he swayed in to my lane tail gating my ***. Next thing you know he follows me so I go slowly trying to race him again. I see his passangers laughin the **** out of me. We were at a light and the bitch revs at me like a ****. So I click the switch and he knew cuz he told me your cheating I ignored him. We took off as soon as the green light came on and I flew by him like nothing. Next thing you know, his laughin passangers and the driver leaves cuz he couldnt take me. So, its possible that si couldve tooken that wrx/
Originally Posted by bgoetz
^^^ (oops go up like 5 threds) lol The thing is I do, and I even acknowleged that when I first posted it. I have a great concept of how fast my civic is and never claimed anything else. I really don't think that those trap speeds are correct, becuase hotrod and I have timed 15.5 sec runs to the tee and I am always between 83-85 at 15.5 secs and that is with him in the car so without I would say that would be 86-88 at 15.5 sec. I originally thought that this method was inaccurate, but it is so consitent that it can't be.
sorry but a trap speed on a track is going to be accurate and proven. your stop watch method is extremely inaccurate, and sorry, but no your trap speed will not be 85mph. maybe 84 with your mods, but that's on your FASTEST run.
your WRX "kill" was not a kill. to list is as one is going to throw you into the "ricer" category. you should stop using a stopwatch to time yourself too, cuz that's going to get you called "ricer" as well. you can't time yourself with a stop watch. you're talking mere tenths of a second in measuring your 1/4 mile. the person who "stops" your stop watch is off too, because you have to factor in human reaction time too. (average human reaction time is .5 seconds.... it's no coincidence that the light tree at a track measure a redlight at less than .500 seconds. hence cutting a perfect light is perfect reaction at .500 seconds)
Originally Posted by HustleLikeM0FO
some time slips and a dyno sheet would put this convo to an end. but since you dont have either one S2Kman is right... prove him wrong with some facts instead of some #s you're pulling out of the air
Oh sorry guys it is ALL ONE BIG LIE....... I am not a 23 year old male with a degree I am a 50 yr old male in a minimum security prison. Hotrod is my cell mate that I use to colaborate my fictional stories. I obviously don't have a civic in fact the last time that I drove was in 1975 before I got busted for bringing cocaine across the mexican border. Sorry to disapoint you guys. Did I mention that I use to be a **** star
actually it's consistently inaccurate, which is why you think it's accurate.
a flywheel does NOT make you faster. a clutch does NOT make you faster. did you just completely ignore my entire post before? you're talking shaving off 5lbs of weight in an entire unit that requires so much a massive amount of torque and power to turn, that shaving 5 lbs is like spitting at a volcano to try and stop it from erupting.
the ENTIRE POINT of a flywheel is to give you better throttle response, which won't make you faster.
engine mount inserts do not help you launch better. they eliminate driveline deflection which helps in higher hp/torque applications to keep a few more hp to the ground. however, in your civic making 120whp, they will do nothing. again... spitting at a volcano.
You don't stop the stop watch you look at the time right at 15.5 seconds. And lets not talk accuracy because you seem to forget that I am a Scientist accuracy is a big part of my profession. This method is accurate + or - 1 mph for the given road conditions.....end of discussion on this issue
your method is inaccurate. extremely inaccurate.
Originally Posted by hotrodcivic2004
believe me s2kman, if there was a track nearby the 'stopwatch' method would NOT be used. but we live in an area where modded cars arent as big as in some other areas of the country. there isnt a track within a good 50 miles of here. i'm not even sure if the ones close by are even public. the stopwatch method at least gives us an idea of whats going on. in no way is it accurate to the .01 second but it'll have to do since we have a lack of other resources.
and dont even give me the whole crap about your trap speed. that you can't even do, since your factory speedo is roughly 2-3% faster than your actual speed anyways.
bgoetz... Please take your super Civic to the track and get it dyno'ed. In every thread you post regarding your car, you quote specs that AREN'T FROM YOUR CAR.
You bring your Motor Trend and i'll bring my Car and Driver... lets do some bench racing!
Ok You take a watch and set the timer for 15.5 sec so the watch stops at that moment. It involves no eyeing at all. You look at the speedo and see were it is at when the watch stops. A civic speedo does not go that fast if you miss by a tenth then it is maybe 1mph. As far as the speedo being off that is funny becuase everytime I go by a sign with the speed it matches perfectly. I am going to use that excuse the next time I get pulled over sorry buy my speedo was off. And lst I check a stop watch is used for many sporting events and practices and is considered to be very accurate.
A stopwatch doesn't give very good horsepower and torque numbers either....
Until you have some verifiable and standardized numbers for your car, don't post them or make claims you can't back up.
Now.... back to my new 500hp issue of Car and Driver.
o wow, i just read that they use a stop watch to get quater mile times....
we should get ready for a server overload when this thread makes it to other car forums ....
Originally Posted by TurboDieselDrew
What is so scary about going to the track? Afraid to run a slow time? Put the stopwatch away and take a trip to the track.
not to mention the fact that a 1/4 mile is measured by distance. you dont go 'well i go 15.5 in the 1/4 mile, so lets time that and see how fast im going'. i can't even argue this point with you any more.
YOU DO NOT USE A STOP WATCH TO TIME YOURSELF IN THE 1/4 MILE OR TRAP SPEED BECAUSE IT WILL NEVER BE ACCURATE!!!!!!
and like it or not, your speedo is off by 2-3%. manufacturer's do this on purpose.
^^^^the thing is I never said anything about 1/4 mile I said speed at 15.5 sec and no the reaction time of hotrods eye watching the speedo would be around .10 of a sec. How do you think we can hit a baseball or duck a punch. If it were .5 sec we could never do any of these things
I am going to go to the track, and I don't care what time I run. It is not that big of a deal to me and will not change the events that took place today
and the wrx wasn't racing. that wasn't a race. he could have been messing with you. even i've done that. messed around with some tool in a car trying to race, and either i dont get a chance to race him again and show him what it's really like if i race, or i dont want to bother wasting the gas, and would rather laugh at a "intrepid beats S2000" story that shows up on the internet.
You know the whole thing is Hotrod and I went out and had a good time and ran 2 races to the best of or knowledge. I myself know it is all true and that we both not some stupid ricers. I thought that I could post two races without people going crazy and flaming me because I had another member in the car with me..........But I was wrong and now we are way off topic so S2k could you please just close this fvcking thread it is useless.
Thanks to those 1 or 2 that said good things
^^^^fine keep it open if we can stay on topic, but anymore off topic bullshit like I want you to take your car to the track/dyno or anything else then just lock it becuase it is stupid
it takes about .3 seconds for the human eye to blink. pretty fast isn't it.
no thats not. i could have my gf post that i owned a viper to back up some made up story that i fabricated. the fact remains that you have no time slips you have no dyno numbers and you keep puliing 130 outa your butt. on top of that you keep posting things that could happen but would be rare like you saying you could take on a turboed civic. i could see one story of you taking on something that would be a hard thing to beet but not story after story.
it's called anticipation. do you realize how fast 5 tenths of a second is? faster than a thrown punch or a 100mph fastball.
