14.2@100.81mph & 3rd time ever to the track....
Old Jan 17, 2005
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
well I went to the track saturday....I dont have a scanner but this is how my time slip goes...
.712
2.278
6.237
9.377
70.52mph
12.046
14.291 1/4 MILE TIME
100.81
still on 8psi (just changed out the HG and finally learned how to launch) ops:
highest trap speed was 101.86mph (ran 101mph+ 3 times) and lowest was 100.20mph (low boost till mid 3rd gear)....ran total of 5 times
on stock tires, full interior....maybe some DR's in the future but I wanna see what I can do when I put in my MM's since they've been in my room going on 3 months and change out my alcohol to methanol (been in garage for over 2 months also)
thats about it I guess...
oh yeah, 13'S, THE SOHC IS KNOCKING AT THE DOOR
note the improvement...first time to track ran 15.4 (blown HG and SHITTY 60') then 2nd time ran 14.8 (blown HG and SHITTY 60') and this time I ran 14.2 so we'll see what I hit next time
Old Jan 17, 2005
allmotor's Avatar
nor cal 7thgens
good times.
Old Jan 17, 2005
NoFriends's Avatar
I like ruining your threads.
Definetely invest in some better tires. Stock are about as bad as they come.
Old Jan 18, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
Congrats on the times again. 13's shouldn't be a problem. Like I said everytime I get close to your times you pull away. Just gonna have to try a little harder when I get back. So hold it down as shreveport/bossier's fastest D17 while I'm gone, but I'm gonna be gunning for you when I get back. JFWY.
Old Jan 18, 2005
JetBlu01's Avatar
New Member
thanx and I'll admit if u hadnt run 15.1 I probably wouldnt have gone back to the track
Old Jan 18, 2005
Redline04's Avatar
We never actually met and it seems that we bring the best out in each other. I just wish I could have been there so I could have possibly dipped into the 14's. I'll admit I was trying to match that 14.8 real bad. Now you just raised the bar again. So as long as I stay nipping at your heels it should benefit us both in the end. Someday I will catch you so you better not stop. . JFWY
At leastYou won't have to worry for next 4 months about me.
Old Jan 19, 2005
JetBlu01's Avatar
New Member
hopefully by the time u get back, I'll be in 13's and hopefully I'll be working on building another D17 block
Old Jan 19, 2005
civic01vtec's Avatar
sweet, that is a good time.........dr's, clutch and 10psi......13's will be easy
Old Jan 19, 2005
HorrorSkopes's Avatar
HorrorSkopes is an unknown quantity at this point
how big is the difference between a boosted civic AT & MT?
Old Jan 20, 2005
JetBlu01's Avatar
New Member
thanx...I think I can hit 13's on 8psi with methanol (in garage)....energy suspension motor mounts (right next to me)....if not 13.9 with those two mods then I'll definitely get it with DR's on 8psi...if not...10psi it is
EDIT: how did u know my clutch is still messed ....this is what I do....I make two consecutive passes then I let the car/clutch rest for AT LEAST 10 MINUTES then I do it again...if not the clutch will start slipping...I plan on getting ACT 4 puck this time...
Old Jan 20, 2005
00celicagts6spd's Avatar
wow, thats some pretty good top end power. your car sux *** to the 1/8 though.
when was the last time you had your car tuned??? gotta be something off to trap 70 at the 1/8 with a 9.3. at 9.3 I'm usually trappin 76 - 77 mph.
but anyways. trapping 100-101 mph in the 1/4 you should have 13's already.
once you figure out whats goin on with your low end power you could get even faster
Old Jan 21, 2005
JetBlu01's Avatar
New Member
tuned??? whats that....
naw man I'm not tuned yet
danace99
23
Jun 28, 2015 08:49 AM
SSMatey
Apr 13, 2015 06:09 PM
supercivic01
South
Nov 30, 2001 11:27 AM
