Civic Vs. SE-R spec-v
I just wanted to know because my friend has a v-spec and he's gotten big headed thinking he could beat any and everybody. I told him I want to race him when I get my swap (which hopfully get started by the end of this year). He tells me would kill me because his car is so tourqy. I told him I'm so sure i'll win that I would put money on it.
Originally posted by Zzyzx
Hm, if an RSX-S is doing 15.2 how much faster would it be if it were 300+ lbs lighter?
How do LSDs work? And is it as easy to take one from an RSX and put that in our cars as is sounds?
HahahaJ/p
A limited slip differential basically is a driveshaft that constantly monitors torque and wheel spin and adjusts power output from one wheel to the other to put maximum power to the ground and keep as much traction as possible. More often than not, LSD's are torque sensitive and also use this to determine power output per wheel. This is especially helpful from a dig, and also when exiting corners.
As for putting one on your civic, the only option I see for you is to get it when you swap in your K20A2. Once you do this, you should have the K20A2 transmission and you'll be able to use any LSD available for that particular setup. As for putting one on now, to mate with your stock transmission, I don't think any are available, mainly because the power output on your civic is so low that it doesn't need an LSD.
Watch out for torque steer on a FWD car with an equipped LSD. Hence torque steer of the Spec-V, MSP, and the like. If you wanna learn more about LSD's visit
http://www.quaife.co.uk/
http://www.marklines.com/en/presen/tochigifuji.jsp
tochigi fuji sangyo is the manufacturer of the LSD on the MSP.
The Spec V has a good engine, just that the header and counter-balance shafts are poorly designed and suck up available HP. I really do think that because of it's better powerband and LSD that it would be able to beat a K20A2 in the quarter.
The LSD won't have much of an effect in the quarter as much as it does in autox/road racing. Though the LSD is nice, it can only help so much when launching. once down the track, it won't do that much.
Quaife said they are supposed to be making an LSD for the 7thgen (low hp output 7thgens don't need one), but who the hell knows, they probably have given up!
As an aside, if you're talking stock Civic vs stock Spec V, I would assume that the tires would be stock too or no? Because stock Civic tires aren't good for ****...those Firestones have screwed me over many a time. Because if you were running a Civic vs a Spec V on stock tires, the Spec V would have an advantage there too.
brill
Nov 12, 2001 07:29 PM
WeRkX
Nov 1, 2001 10:33 PM
