The long awaited 16.01 *Video*
http://www.zacknetwork.net/project2k2/1601.wmv
sorry it's low quality, just figured I would save u the load time.
Also the music in the background is coming from the grand stands.
Shoulda taken a dump. That extra 2 lb less might have helped.
Smaller wheels and shorter gearing (by tire diameter) and you probably would have hit 15s
Dude, I wanna see your 60 foot times. I bet they suck. You need to do a better burnout. Get those tires nice and stickey, especially in this cooler weather.
Steps:
1. Rip up on the hand brake
2. Rev up really high
3. Pop the clutch and let those badboys spin
You will be able to burn out forever!!! Whenever I get done with my burns I always have rubber flung everywhere over my car and my tires are melted with rubber goo. Also drop a ton of tire pressure.
It would be better if you swapped out your good rims for your stock steelies, can then you could drop your tire pressure down to about 10psi. Then you should hit your 15's.
Steps:
Originally posted by bublik
how are those rims doing man? You having fun
and fly, I would have put my stocks on, the only problem was that we didn't have any type of pump so that when I came home I couldn't ride on a 18 psi tire.....next time.....January 9th.
Truehonda.com
Hey man, if you ahve those tires that came with them, I dont think you will do that hot. The nitto 450's are not always the best for grip. Pick up some bridgestones or azenis for overall performance.
ballmich
Jul 9, 2015 11:59 AM
92hatchbackcx
Jul 7, 2015 08:23 AM
BootyDo
Jul 7, 2015 06:06 AM
