On the way to work
Old Oct 7, 2003
GunnerX17's Avatar
GunnerX17 is an unknown quantity at this point
On the way to work
Around 7:30am this morning on my way to work I lined up at a red light behind a 2003 Mustang GT. To the right of the stang was a dropped pearl white 7th gen (stock body) civic (don't know if anyone on here owns it). The mustang was the first to rev up *drool* i love how the throaty v8s sound. At first I the civic owner didn't respond, but after a couple seconds he decides to play too (cleanest sounding bov i've heard in awhile) . Well the light hit green, the civic got the jump, with the stang launching soon after. The street was only a 4-lane, so I just tailed the stang a couple car lengths behind. It never gained a single inch on the civic. I shut down in 3rd gear, coasting at 50-60...Seemed the civic had maybe a bus length on the stang in the end . At the next light, i see them lined up again, talking to each other. They both give a thumbs up and cruise on their way.
Nice way to start an otherwise boring day at work.
Old Oct 7, 2003
nme3's Avatar
JDM wannabe
nice! a turboed vic? you should have talked to him and mentioned this site if he didnt know.
Old Oct 7, 2003
tripledoublegs's Avatar
Euro-Spec
yeah, most likely a turbo vic. Good kill for the Honda.
Old Oct 7, 2003
NeonImpact's Avatar
Forum Sponsor
if it wasnt a turbo, then it wasnt a civic..
Old Oct 8, 2003
Connie's Avatar
so true
Old Oct 8, 2003
Got Boost???'s Avatar
Hmm to the best of my knowledge you WON'T hear a blowoff valve when your revving. Why? cause boost isn't created until you put a load on the engine. And you can't but a load on the engine while remaining in one place (except on a dyno or doing a burnout). I can go outside and fire up the mazda and rev all day and no boost will be created. This leads me to believe one of two things 1). Your full of sh*t or 2). He was purging nitrous which makes a sound similar to a blowoff valve. Either way the sound you heard WASN'T a blowoff valve.
Old Oct 8, 2003
GunnerX17's Avatar
#1...reason you probably can't hear it on your mazda is because it's a TT (asuming you're talking about an FD)...disable your 2nd turbo and it will be a lot more audible even if you don't build boost and rev from a stop.
#2...you might still have your fire blanket attached on your hood...that deadens the sound of the bov more than you could imagine.
Yes, the BOV is a lot more audible from a roll after the turbo spools...that's a given. If you insist that it wasn't the BOV i was hearing from a dead stop, i'll put up some sound files of me revving the supra in neutral and you can judge for yourself.
Old Oct 8, 2003
No i have the B6T motor with the single in a 323 GTX im not going to pretend to have some fantasy car cause i don't. And now that i look at your sig you too should know (if you really have a supra) that boost won't be made when theres no load on the motor.
1) You don't DISABLE a turbo
2) This is a fact, you will not hear the sound of a blowoff valve when no boost is being made, the purpose of a blow off vavle is to release the pressurized air preventing the air from slamming into the throttle plate and backing up into the turbocharger itself. The sound you hear is the pressurized air being released and going out the blow off valve. So how can the air be pressurized when you aren't making any boost?
3) You obviously don't know much about turbos
Please make these files
Old Oct 8, 2003
C2i0v0i1C's Avatar
SuperMODrizd
i can hear mine when i rev close to redline and then let off, its not nearly as loud as driving and shifting but it is noticeable while sitting at a light
Old Oct 8, 2003
GunnerX17's Avatar
Alright, i'll record and post it by saturday
Old Oct 8, 2003
GunnerX17's Avatar
FYI...I actually DO disable my 2nd turbo for now when i take my car to road courses. I've only been doing road courses for 2 months now and the 2nd turbo is a little more than I know how to control right now on tougher corners. Until i get better at it, it's too dangerous for me to risk the 2nd turbo kicking in when i goose the pedal out of a turn. Anyways, on the days i go out to the courses and disable the 2nd...the bov is a lot more audible.
Old Oct 8, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
ok WANNA KNOW WHY u dont hear the BOV? cause u have a shitty one. honestly... not tryin to sound like a ****.. but its true... i have the Turbo XS one .... u dont hear crap at idle... but if i went out and bought a Turbo XS Type H RFL BOV u would here it all the time... WHY? cause they have horns on them that create crazy PSSSSSSH.. even at IDLE... ur BOV IS blowing off at idle u just cant hear it ... i promise you ... reason why u herd the civic is cause he had a loud BOV. .. hmmm here look... click this link.. this is the BOV im getting... Turbo XS RFL BOV on a WRX reving at IDLE....
Old Oct 8, 2003
link not working
Old Oct 8, 2003
GunnerX17's Avatar
My host is sucking i'll have my friend put up my soundclip sometime tomorrow...
here is the wrx he was talking about
http://www.935motorsports.com/media/turboxsrfl.wav
C2iOvOi1c - Im really diggin your setup bro. Too bad you're all the way in ohio, i'd love to see that beauty in person.
Old Oct 8, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
oops forgot the link.. lmao yea thats it.. thank you.
Old Oct 9, 2003
GunnerX17's Avatar
link not working
Got anything else to add to the subject now that the link is up?
Old Oct 9, 2003
Actually yes i do, i have also done some further research into this and have found that my initial statement was incorrect. I was speaking from experience, not fact. Every turbochraged car ive driven/riden in/worked on, will not create boost when you rev in neutral. The vaccuum will dispearse however no boost. As i found that some BOV, the TurboXS in particular, will allow the car to generate boost when no load is on the engine.
Old Oct 9, 2003
GunnerX17's Avatar
Old Oct 9, 2003
Hawk's Avatar
You boost, I-VTEC
my friends eclipse with a Greddy bov blows off in neutral too. when i drove it i played with it at a light.
Old Oct 9, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
yea i know.... got boost is a moron.. cause all BOV's do it.... he must have worked on VW's and audi's..
Old Oct 9, 2003
try mazdas, mitsu, and subaru
I have no problem admitting when im wrong, but i have a real problem when people act childish about it. I have much more respect for GunnerX17 because he proved me wrong and instead of going "HAHA YOU MORON YOUR WRONG" like you did, he did the more civil thing and simply acknowledged my response. You on the other hand have done just the opposite by resorting to namecalling.
Old Oct 9, 2003
EviLMyStS's Avatar
All show!!!
*sigh* what the hell is people's problems nowadays... Anyways to that 7th gener
Old Oct 9, 2003
Chocobo's Avatar
Chocobo is an unknown quantity at this point
yeah, back to the subject
werdnahall
May 17, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
