1999 Honda Civic SI
It has been awhile since I have been on this forum. I do apologize, but I was in Afghanistan at the same time. I am now back in the states and have had the chance to drive my baby that I bought while I was over there. I put on the new shoes today. In case anyone needs to know, here are the current specs:
B16A2 (45k Original miles on motor and body)
Eagle rods
JE pistons
Bored .5mm Over
440cc injectors
Full Greddy Turbo System w/T28 Turbo running 8 PSI
Tokiko Blues
Falken Ziex Tires
Buddy Club P1 Racing Wheels
Exhaust is running off the downpipe right now and still need to get the APexi' WS2 Catback sitting in my garage put on right now. Ill be using SpeedFactory's services for this. I also have a new Walbro fuel pump with and a few other things to add on here and there. Ill post a video of it on Youtube when I get a chance.
The car pulls hard... and i mean hard. It's quick. I think I will also dyno it next saturday and see what is really going on here. Here is a pic I took just today after I put the new wheels on.
Eagle rods
JE pistons
Bored .5mm Over
440cc injectors
Tokiko Blues
Falken Ziex Tires
Re: 1999 Honda Civic SI
I have noticed a few things after driving my EM1. The first and probably the most major of the problems is the sound that I am getting from what seems to be the tranny when I decelerate in 1ST AND 2nd gear. It doesnt make the sound in neutral. The sound is like a grinding/whining noise. I was thinking the input shaft bearing, but not entirely sure?
The second problem happens when the accessories are turned on. The idle seems to lope from 800-1400 RPMS. I havent checked the IACV or TPS yet, but I did just replace all the grounding wires.
Opinions would be appreciated. Thanks guys.
Live for the Twisties
Thanks everyone! I really appreciate it. Yes it has only 45k original miles. The paint is original too and needs some waxing and buffing but is still pretty clean. Its going to Speedfactory this weekend to get some diagnostic work done for the small things, since I dont have the time. I will def post more pics after I give it a bath and clean up the engine bay. Im posting from my phone, so Ill have to get on my comp.
Soo all my worst fears came true. The input shaft bearing is failing :/ soo the tranny needs to be pulled and the case split to get to it. Its a 20 dollar part, but 600 dollar job. The tune that the current turbo setup is using is a base map, which is why I am getting the idle lope. Its getting dyno tuned today and the tranny will be pulled monday. I am also using a new MAP sensor and installing a Walbro Higher flowing fuel pump.
More pictures soon! Will also post a 1st/2nd gear pull on youtube.
Will scan and post the dyno sheet too.
True... Generally I like to do everything myself, but I dont have the time for this... Like at all. I am working everyday for ten hours and then I have an hour commute each way for work. Time is money in this case and I am paying for time I dont have to spend. Im also working on my 88 YOTA 4x4 quite a bit too. Its been a bit of a project since I bought it.
Another update for my baby. Walbro 255 LPH fuel pump installed, SF MAP Sensor installed, input shaft bearing replaced, preventative maintenance on transmission done, Down-pipe re modified so that Oil return line for turbo wasn't touching, oil return line replaced, cat delete, turbo re-tuned at 12 psi via dyno.
As promised, here it is:
More pics to come soon
I am using a Greddy T28. So the boost is pretty much maxed out anyhow. I need bigger injectors and a bigger turbo to go anymore. I would have to also start beefing up the transmission too.
Im noticing a fast clicking sound as Im driving in every gear. Im also hearing that 'grinding' or 'humming' sound when Im decelerating in 4th, 3rd, 2nd, and 1st. I know whatever it is, its going to cost some money but I wanna try and pin point what it is.
Sounds like the CV axles. Mine started out like that. Just a few clicks. Then grinding. Lol. What sucked about my situation was the boots weren't torn. They were just old and I guess the grease just stopped doing its job. If they've never been replaced, now's the time. Mine went around like 135k. I also changed the transmission seal too when I did mine.
I'd assume so. I never heard it on the freeway because of road noise. But the click went with the speed of the car. The faster I accelerated the faster the clicks got. The grinding showed up a week or so after the clicks though.
