Rear Bumper Ding?
Old Apr 4, 2008
SSMCivic2k5's Avatar
SSMCivic2k5 has a spectacular aura aboutSSMCivic2k5 has a spectacular aura aboutSSMCivic2k5 has a spectacular aura about
Rear Bumper Ding?
Hey guys,
As some of you guys know, I hit a old cadillac on this past wed. and cracked my whole bumper in half. Now i do not want to pay 600 for a OEM one......I was on ebay and saw this bumper for $150 and it has those marks where someone bumps you with the license plate holder.......you think is this easy fix???
Old Apr 4, 2008
popee's Avatar
popee will become famous soon enough
Re: Rear Bumper Ding?
you better off jus paiding for a replica bumper on ebay....
01-03 http://cgi.ebay.com/ebaymotors/BUMPE...spagenameZWDVW
04-05 http://cgi.ebay.com/ebaymotors/NEW-P...spagenameZWD1V
Old Apr 4, 2008
buckshizzo's Avatar
buckshizzo is a jewel in the roughbuckshizzo is a jewel in the roughbuckshizzo is a jewel in the rough
Not an easy fix. Having it fixed and repainted would end up costing you more in time and money. Just get a replica it would be cheaper. Fitment might be an issue with the replica since it's not oem.
Old Apr 4, 2008
oh this bumper is already OEM...
Old Apr 4, 2008
buckshizzo's Avatar
The marks don't look that bad on that bumper. If you can't live with it and want to do it cheaper, you can try to fix it yourself.
Old Apr 4, 2008
maybe with some bondo and sand?
Old Apr 4, 2008
buckshizzo's Avatar
If you try that. You can wet sand using 1500 to 2000 grit sand paper and apply minimal pressure. You can also use touch up paint and sand that down.
Old Apr 4, 2008
i was thinkin of getting a lip to cover it up also a little bit. soo whats the steps i should take?
Old Apr 5, 2008
popee's Avatar
if you wanna try and fix it.. .. wet sand it wit 1000-2000grid paper.
Old Apr 5, 2008
what the exact steps i should take???/ like sand it, prime, paint......
Old Apr 5, 2008
popee's Avatar
yea .. wet sand .. wit 1000-2000 than prime than wet sand agian to smoothing things out - than prime agian .. sand they use paint thinner to clean the bumper than .. paint
Old Apr 5, 2008
VP Stylee's Avatar
VP Stylee is an unknown quantity at this point
use the 1000 when you are getting the paint off and smoothing it out, and make sure you use a sanding block. use a damp rag with soaked with paint thinner to clean it before paint or bondo
if it has indentions in the actual polyurethane you can buy a tube of bondo and hardener at autozone/orielly's for 5 bucks to repair it(what i did to my front bumper) sand it down with the 1000 grit again until it blends
then get you a SSM spray can kit from paintscratch. let it dry for an hour or two then clean it with a tack rag(orielly's $.99) in between coats
use the 2000 grit before you clear to smooth any bumps .
you can use 2000 to shave bumps on your clear but not on your final coat.
keep using the tack rag to clean it between, and give the clear a little longer to dry than the paint.
let it all cure over night before you put it back on
Old Apr 5, 2008
thats too much work for me! haha... i rather have a place do it for like $100
Old Apr 5, 2008
buckshizzo's Avatar
Lazy.
Old Apr 5, 2008
hahah seriously
Old Apr 5, 2008
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
hahaha wow, just bring it to a shop, i would do it at my shop for 150-200
henrytn
Aug 11, 2015 10:01 PM
Mig21
Aug 7, 2015 10:55 AM
jpandjf
Aug 3, 2015 05:02 PM
gmiguel
Jul 30, 2015 10:52 AM
SpecialRequest
Jul 7, 2015 07:52 PM
