HID Fogs In = Awesome Glare!
Diamond Member
Haha well everyone else has threads for their car so I figured Id keep an updated one of mine
I got quite a few things sitting on my bedroom floor
that are going on the next few weeks. Ill keep this updated. Also, Im budgeting around $175 from taxes to spend on the car. Should I buy a set of freshly powdercoated fat fives around here? Or what are your suggestions? Anywho, heres the first mod:
Guess what they are!
Im going to try to wire them differently, and if you see a fatal flaw please correct it. Instead of going through the hassle of putting them on a relay and switching that and wiring it directly to the battery since my terminals already full, Im going to switch a power and ground from some 4 gauge wire going to my 4ch amp. Its already fused to 120amps, and quite frankly, i dont mind buying switches every 6months. Simpler=Better for me. I also have some megan racing + pioneer goodies in the bedroom too
as well as a spare set of oem 02 tails.
Re: My Cars Thread: New Springtime Mods
"to 120amps, and quite frankly, i dont mind buying switches every 6months"
does this mean your lights wont work with a blown switch?
what if it goes out at night?
Diamond Member
well these arent headlights. but if the switch blows them the ciruit cant be completed. so technically no. but this is just the impression i got from searching,
i've never used a relay harness for my HIDs, just always spliced straight into the headlight wire, used some heat shrink, and tucked it all away. i know someone will get on me about it but my car has been like that for over a year, daily driven, no problems whatsoever.
Diamond Member
yea i bought like 50 feet of 12Awg wire. Plenty of extra =D
i went out to test em today and turns out both bulbs work, however, one ballast just smokes and burns when connected. Along with a high pitched whistle. So i guess ill have to mount the projectors with only 1 HID.
EDIT: getting a replacement on the ballast at no cost. excellent service for a nonname ebay store and brand!
Diamond Member
just put 3 10" subs in my car, it buMPS! two alpine type-r's and a pioneer. pics soon. im also going to be ordering the Alpine MRP-M1000 for 1000RMS watts for these puppies. right nowtheir getting 700rms. cant wait. i havent installed the fog lights yet, but i ran the switches and the wires, and my way of switching decbired above actually works like a charm. i should get a new ballast by friday and hopefully itll be mounted by next monday.
Diamond Member
FOGS ARE ON!!!!!!
Installation Pics!
No Bumper
Mounting Position for Ballast
The Hole
The HoleSaw- 2 and 3/8" hole saw perfect fit with a lil trimming for mounting bracket.
Halogen + HID both Lit on Switch
Final Product
Nightime Pics
Fogs only
Right Side Cutoff (Halogen) Very Nice!
Heads+ Fogs
Driveway Pics
Garage Door
Installation Pics!
No Bumper
The Hole
Final Product
Nightime Pics
Fogs only
Heads+ Fogs
Driveway Pics
Garage Door
Diamond Member
question for the projector knowledged:
Does it matter if theyre aimed upside down?
Because both of mine are upside down, and quite frankly, the output sucks. when i get the second HID ballast in, Im gunna re-aim it all and adjust the HID projector on the right. Its kinda aimed straight at the ground and off to the left.
Im glad to finally be one of the few with projector fogs!
Any Q's about installation, Im open for questions
wow lol yeah all the light is going into the sky. get those turned around, and to me the halogen looks better by far. hid beam is all messed up. are those blazer fogs? turn them around and aim them just like headlamps. 2 inch drop from the center at 25ft.
to change title, just advance edit your first post.
Diamond Member
Re: HID Fogs In = Awesome Glare!
ok thanks for title change info. and yes, they are blazer fogs. and yes, OMG do they need to be aligned again. haha. i think ill need to bust out some bondo to remount them.
u got 8000k? big mistake...... i wouldve gone with 3000k or 43000k cause the projector is givin more light from halogen.... or maybe its not aimed right?
halogen still looks brighter idk. 6000k is almost as dim as halogen anyway (2400 lumens at best). but i guess bulbs are cheap and you can always change it later.
Diamond Member
3000k: yellow
4300k: white
6000k: "ultimate white"
8000k: white with blue tint
12000k: purple
no other colors. i really wanted 5000k so i may just buy some bulbs. i just want some blue output lol. if you look at them straight on, (not the misaligned way they are now) they actually look white with a hint of blue, versus straight up blue. so idk, i will definelty post pics once i get it properly aligned. and we can compare halogen with 6000k HID's
Diamond Member
i actually mounted the ballast in an open part of the frame where im guessing the reinforcement bar is supposed to mount? the ballast fit right inside, almost like a fabricated piece just for it.
heres what the colors really look like.
3000k = pure yellow
4300k = oem white
5000k = crisp white with small blue tints
6000k = white with alot of blue tints.
8000k = mostly blue
3000k = pure yellow
4300k = oem white
8000k = mostly blue
MamaBear2015
Sep 24, 2015 11:34 AM
TheRiddicles
Sep 21, 2015 01:28 AM
MamaBear2015
Sep 4, 2015 09:04 PM
