Wheels/Suspension HELP!!!!
Old Feb 19, 2007
CivicFreak03's Avatar
CivicFreak03 has a spectacular aura aboutCivicFreak03 has a spectacular aura about
I am about to order a set of 18'' wheels wrapped in a 40 series tire. I am also going to order a camber kit because I plan on lowering it. Here is my dilemma: I want to have all of this installed at the same time so I need to find springs that will NOT rub and give me a 2 finger gap or a lil more. Does anyone have any idea of what spring would be ideal? If you have a similiar setup on ur whip can u post pics so I can get an idea. My biggest fear is getting every installed and then the wheels start to rub. Help me out please!!! Thanks ahead!!!
Old Feb 19, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
it depends what the offset of the wheel is and the width of the rim itself. Also what size exactly is the tire? 215/40/18? and you shouldve posted this in the suspension section.
Old Feb 19, 2007
they are 18x7.5 wheels and yeah 215/40/18....also I will be using stock struts for now....
Old Feb 19, 2007
AmbulanceMonkee's Avatar
it also depends on the car. do you have a 7th, or an 8th gen like your avatar?? i believe the new civics come with larger wheels, and will handle an 18" wheel with less issues than the 7th gens.
Old Feb 19, 2007
miklovo's Avatar
miklovo is an unknown quantity at this point
I had Eibach Pro's (1" drop) on 225/40/18 tires 18x7.5 rims without a camber kit with stock everything else and did not rub at all...even when I hit big junk in the road. With this setup I had almost 2 fingers in the back and excatly 2 in the front. Lemme see if I can get the pics posted...they are on my other computer.
Old Feb 19, 2007
I have an '02 civic
Old Feb 19, 2007
miklovo's Avatar
Here they are:
The first is the stance with the Eibach Pro kit and 18' Motegi MR-7's. 2nd pic is is back and the 3rd is the front. This setup never rubbed or hit (without camber).
ID:	69736   Click image for larger version
ID:	69737   Click image for larger version
Old Feb 19, 2007
Kevbotron's Avatar
I like my commute
yeah here's another vote on the ProKit, it's a good drop... it's about 1.3" drop and you can take your time getting all your components (camber kit and shocks) because you WILL need them eventually.
Old Feb 19, 2007
do the tein h techs give a similiar drop? Any reviews on them?
Old Feb 19, 2007
miklovo's Avatar
The Prokit is 1" drop and the Sportline's are 1.4"
I have a set of H&R's now and they're 1.3"
And yes, after 1 year of the Prokit my back tires were shot from the neg camber
Old Feb 19, 2007
Kevbotron's Avatar
I like my commute
^I think the 1" is just on paper... it seems like a general consensus when it all settles it's about 1.3"
yeah, my rear tires were shot too I need warm weather to put my SPC kit on!
