help with slicks!!!!!!!asap
Old Feb 12, 2007
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
hey guys im in need of slicks n rims asap. i have a 04 ex coupe turbo. i plan on etehr gettin 15 inch slipstreams or 13 in lensos. what size slicks can we fit on our cars wit no probs. and how much hp is pused with thoses. i herd 22 inch slicks are a comine size and i herd if you get slicks that are to big you wont spin em and youl brake an axle and your tranny.. leme know asap!1 need to buy asap! thanks
if you do have 22 inch slicks what are your trap times??
Old Feb 12, 2007
helpme!!!
Old Feb 12, 2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
u know you posted this in 3 differnt sections it seems like and i responded to both.. what gives??
its ahrd to tell you what slick sizes to use..
the the amount of power you push is one factor..
and how you race is another...
you could have a 500hp car and not break a single stock axle.. just depends on how you race it.. if your worried about breaking an axle i wouldnt worry about what size slicks.. i would rather worry about getting stronger axles first
Old Feb 12, 2007
wut size slicks do u run ..what are teh specs? hw much u pushin power wise?
Old Feb 12, 2007
thats 2 u x
Old Feb 12, 2007
i have 3 sets of slicks and 2 different drag radial sets..
i set of 23 on 13in lenso
i set of 24.5 on 13in lenso
and i got another set of 26 no rims yet
this is for me running a k-series motor.. its irrelevant to comapre a D and a K because the motor outputs are different as well as the driver... you got someone who could preload the clutch so they dont break axles versus someone who drops there clutch..
Old Feb 13, 2007
r u stock k 20?
Old Feb 13, 2007
phantomninja's Avatar
phantomninja has a little shameless behaviour in the past
how come not get konig heliums? only like 90 a piece and weights like 11pounds, how come you dont try launching your car as it is now and then think of whatever size tires you need from there, theres a huge difference from doing a good launch and just dropping the clutch, you should only hear acouple chirps on a good launch i think haha
Old Feb 13, 2007
Originally Posted by HwNpRyDe_CiViC
r u stock k 20?
semi built...
i got another motor going in to the car in a few weeks... fully built k24/k20 frank 9:1 compression bossting 20psi...shooting for at least 500hp
Old Feb 13, 2007
nice....bump for u sir
