What should i do!!!!
Old Dec 5, 2006
mr.rowdy's Avatar
mr.rowdy is an unknown quantity at this point
Ok guys im in a bind.. What do you all think i should do? Not looking to go real fast but faster.. So should i keep my D17 and build it up or should i to a k20 swap,, and how much you think i could do the whole swap for???
Thanks guy
Old Dec 5, 2006
sl33pyriceboi's Avatar
1. k20swap will be alot better than a build d17... (and less maintenance)
2. search......anywhere from 4-9k
Old Dec 5, 2006
tuner04civic's Avatar
spell check pwns you
depends on a
1. k20a the japan motor 5k
2. k20a2 the rsx-s motor 3k
3. k20a3 civic si motor or stock rsx 1.5k
than add 1k for mounts and wiring harness
add another 1k for hondata for it to run corectly
add another 1k for install and tune
accessories to finish up the install 500
these are all estimates. and depends what yu get with the motor.
whatyou want to see if comes with the motor if not you will need.
- AC compressor
- alternator
- P/S pump or idler pulley (from Civic Si)
- wiring harness
- exhaust manifold
- keep civic cat and modify midpipe
- ECU
- Disabler
- Transmission and starter
- intermediate shaft
- Axles from either 02 Civic Si or 94 up Integra GSR or RSX with RSX knuckles and hubs
- RSX or 02 Civic Si subframe
- Hasport ESK1 bolt in mount kit
- Hasport ESKWH conversion wiring harness
- RSX shifter assembly and cables
- 02 Civic Si radiator and fans (although the RSX will fit with some trimming around the radiator cap opening in the grill)
- 02 Civic Si upper and lower radiator hoses (RSX are longer and may kink)
- RSX throttle cable
- RSX fuel line, brake booster line and purge line
- RSX AC line from compressor to condensor
- RSX clutch lines from the master cylinder to the slave cylinder
- Custom AC line from compressor to evaporator (Hasport should have one available by April)
- 90 Accord negative battery cable
- If you want powersteering:
- RSX high pressure powersteering hose and return line
- 92 Civic P/S resevoir w/ bracket and a section of hydraulic hose to go from the pump to the resevoir
Old Dec 5, 2006
mr.rowdy's Avatar
So it'll cost about as much as my car huh
Old Dec 5, 2006
CenZ's Avatar
PWIT
on average a k20a2, overall cost about 6k
Old Dec 5, 2006
dru106's Avatar
ThE CoRRupToR
mines was just a little under $7k cuz you will run into some trouble here and there and a lot of misc stuff like hoses, clamps and fluids
Old Dec 5, 2006
spoonEM's Avatar
omgwtfbbq mod.
your best bet would be to eat a delicious chili dog.
.....oh yeah, and use the search button. youll notice in the top bar there is a search feature. youd be amazed at what it can do seeing as to how there are about 356257247 topics regarding k swaps.
Old Dec 5, 2006
mr.rowdy's Avatar
Originally Posted by Sujak
For about the $6-$8k people spend on their swaps you can can have a semi built D17, Turbo kit, and a AEM EMS if you want and make around the same if not more power.
I would build a d17 and boost. but if i wanted to be like something unique i would K-swap.
Or im sure you could get a nice k20a3 swap in for about $$4000-$5000 including labor... (price may vary alot due to shop pircing.. IL has nice labor costs )
Everyone tells me that there is a **** load of maintance if you build a D17 is that true
Old Dec 5, 2006
mr.rowdy's Avatar
Sounds like a good idea cause im not trying to go real fast just fast enough that when some *** comes up next to me I can either take them or give them a good run
Thanks
Old Dec 6, 2006
mr.rowdy's Avatar
Well and i found a guy that is going to sell me his motor and tranny maybe
Old Dec 7, 2006
dirtySAMURAI's Avatar
I log in from time to time
trade your car in for something faster.
Old Dec 7, 2006
goodtimes's Avatar
now someone who knows what there talking about
Old Dec 7, 2006
TRIZ's Avatar
Thanks
you want to go fast and you know it. haha... You know, it really sounds like you should check out nitrous. Sounds like the perfect option for you- some *** pulls up.. activate it, boom- take off. Takes pretty well to an automatic if thats what you have. Anyways- there is a bunch of threads in the fourm for nitrous as well.
enjoy
Old Dec 7, 2006
spoonEM's Avatar
omgwtfbbq mod.
I always say the best upgrade for a civic is an rsx type s.
