mmm Turbo sneak peak and 01-03Grill on my 05!!
so i got the kit as all of you know...but some stuff i didnt like...i.e. the fuel mgmt that it came with so i sold the safc2 and i still have the tsi fuel unit but i think im gonna throw that out...
as you can tell i have 2 bovs one is the tsi one and the other is a HKS ssqv...had to upgrade
next that manifold does NOT come that way from tsi...
i had it ceramic coated in black by a local place...not only does it look better...but its efficient in holding heat in cause the ceramic is inside the ports also...=prevents heatsoakso all i needs in engine mgmt...but i want to get a vis carbon fiber hood first...
its greddy emanage vs aem ems...if i can afford ems i will get it...but obviously emanage is cheaper...
oh and heres a picture of the grill (01-03 "Type R" Grill) on my car...i think its better than my homedepot ish...from the picture you can see how it doesnt fit...the minor gap on either side...i dont care its a tradeoff...i like it!
i took it at that angle for a reason...to show you...
from the front its not as bad...hey its better than my homedepot mesh thing...(look in my sig for that ugly pos grill)
too bad there are no aftermarket grill...so this is the best i can do now...i think its alright...i can always fill in the gap with diy fiberglass and stuff...
Does an upside down starion intercooler fit well in the front of a 7th gen? They are a pretty nice core and can be picked up cheap. I was planning on going with the small $80 bar/plate intercooler off ebay but I have used a starion ic before and even with the tiny charge pipes was able to make pretty good power.
Later
Randy
Later
Randy
^^ha-he must of fallen in all that water!.
i have the same kit on my car. get e-manage for it. simpile upgrade and works great. oh and that IC pipeing is a pain in the ***. the pipe that comes down off the turbo needs to be 1/2 inch longer or else it will rub on the engine mount and eventually make a hole in itself. pluss u r going to have to drill a hole for the IAT sensor. but it is a good kit non the less.
boost junkie- u posted at the exact same time as i was writeing that!
Last edited by drunkenmagnum; Aug 28, 2006 at 10:24 PM. Reason: Automerged Doublepost
im kind of torn between the 2....turbo or swap.....i gotsome parts for the swap but the turbo sounds so tempting.....i can do it faster then a swap but swap is so muich cooler but turbo is just as cool .....d'LAWMilngfakjfds nvawe!~
i can always have **** fabbed up during mock up...but this kit was installed before and it doesnt look like the pipe is that bad...i know in the pic i have 2 pipes mixed up (the one coming off the throttle body and the one coming off the turbo...correct?)
drill a hole in the IAT? you mean in the intake tube for that sensor?
do you have any pics of your install or anything?
go turbo. to me seeing a boosted d17 is a little more unique than a swap and it is way cooler when u r faster. pluss it is cheaper in the long run.
but then that means i got k20 parts sitting here for nothnig
we will see what my next job is...im prob gunna quit and try to get a good paying job anyone know somewhere? with goodpay
Originally Posted by Boost_Junkie
also how you like the manifold? looks better ceramic coated eh? got pics? read above^^ answer my questions!! haha
so the thing in our intake has to be extended to the new intake blah!! ok i can deal with that...
and that pipe that rubs can be wrapped with something or a shield can be made...
where them pics at?!?!
yeah the intake air temputur sensor. it might cause the engine to throw a code once and a while without it so u might as well go ahead and install it. wont take but a min.
Bitch can wait for the new furniture, I'm getting a turbo next summer
