Aftermarket Steering Wheels?
Thinking of swapping to a momo wheel on my 02 coupe... would the airbag light come on, since the airbag connector will not be connected? and the cruise will have to be disabled right? unless i do that diy on relocating the cruise? anyone? im more concerned about the airbag?
The World Is Yours!
momo on coupe
well...my SRS light came on when i did my seatbelt swap, but other than that, i unplugged the battery for at least 1 hour or more, then i unpluggedd ALL srs related fuses. then 1 hour later i took out the cruise control 1st, but remember to go to sears or local parts store and get the spline/hex head tool to remove the steering wheel. i have not crusie, btw...
Originally Posted by MoniraInc
i'd rather have an air bag...
Originally Posted by Burr
a harness would do without an airbag..
So a harness will save your life in case you crash? If you hit a truck that was coming your way, will the harness form a web to save you from the disastrous?
Didn't think so.
i have the same wheel
all i did was disconnect the srs wire from the gauge cluster so the light no come on
Didn't think so.
Last edited by jamesandrew58; Aug 18, 2006 at 03:35 AM. Reason: Automerged Doublepost
so other than disconnecting the srs wire from the cluster, there is no way of getting rid of that light right?
what do you mean put in a harness? with aftermarket wheels, you have to leave that airbag connector disconnected.. right?
being on the bright side.. driving with a aftermarket wheel is hella lot safer! with factory steering wheel, yes the airbag will prevent you from hitting ur head to the wheel by cushioning your head...
but if you want the look and feel of a smaller wheel, you can just swap that sucker out.. and drive around in a helmet on your head... voila! done.. problem solved... you can do head-ons without serious injury to your head, and yet have a aftermarket wheel! =D
oh forgot to mention that many die from suffocating from the airbags.. tsk tsk tsk.. =D
Last edited by qgt_racing2000; Aug 18, 2006 at 01:30 PM. Reason: Automerged Doublepost
Originally Posted by qgt_racing2000
mugen hub? where can i find one of those.. and how much?
OptimisticWay
46
Oct 15, 2015 02:16 PM
Dave1984
Jul 22, 2015 06:10 PM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
