Heated wiper fluid for 7thgen Civics?
Racism sucks, just like your Mom...
I know some of the newer vehicles out there have the option of heating up the wiper fluid. Is that strictly an OEM thing or does anyone know of an application that can be used, maybe even adopted, for the Civic?
No, these don't count...
http://www.everblades.com/
And, preferrably, cheaper than these...
http://app.infopia.com/Shop/Control/...sid/0/rid/4056
Only viable one that I've been able to find is this:
http://www.windshieldwiperheaters.com/
Anyone do this to their Civic? Any ideals?
just keep an ice scraper in the car. once you get moving you can keep the wipers on and nothing will build up.
Originally Posted by gearbox
ya they make em and one brand overheated and drained the battery. dumb if you ask me. washer fluid doesn't freeze anyway
I know we have a DE-frost. Still, I thought it'd be nice to be able to melt off the snow and frost without having to stand outside and scrap it all off in the cold. I guess it's just me, though.Gearbox, I'm assuming you had one and that it wasn't a pleasant experience. Do you remember the name-brand?
They have that here at Canadian Tire (in Canada)... 60bux CDN
http://www.canadiantire.ca/assortmen...romSearch=true
yea thats the one that had the recall i believe for draining the battery and melting some wires. and if its snowing I bet the washer nozzles are plugged up anyway so you still need to thaw them with your finger or something.
The **** does work. It breaks down salt and **** that gets on the windshield better as well. It can also break down ice buildup on the blade itself. For the money, and if you live where theres lots of snow, ice, and salt like me, it does help
Originally Posted by KINGCHILE
Just throw a towel on your windshield over night and take it off in the morning. That should take the ice or morning frost off with no prob. Plus its cheaper.
Get low resistors and cover it with sealant. Then add a switch to the resistor. Perhaps something to mix up the fluid. That should heat up windshield wiper fluid. That's the cheapest and easiest way. I thought about doing it to my car, but I live in FL. Doesn't get cold enough down here.
Originally Posted by civic4dizoor
^ im pretty sure its not HOT boiling water
I bought it.Went to install it but couldn't find a place to put so I threw it in the corner.It heats the fluid up to 60 degrees.It unclogs frozen nozzles and clears your windshield in 10 seconds.With the heated fluid in the summer it cleans the bugs off in seconds.I know there was a recall on it though.You can get it factory on the Buick Lucerne and I'm sure there is others.
Actually, I was thinking that it heated it up far greater than that. The Buick Lucerne has it where the fluid is heated to 149 degrees, so I'm wondering why yours is only going to 60 degrees.
Oh, wait. I think you meant Celsius, right? That would make it 140 degrees Fahrenheit...
I went to Canadian Tire and took a look. Didn't send me to the item, so I did a search and came up with this: The Motomaster HotWash. Is that the one you were saying had a recall?
What about HotShot? Has anyone heard of it? Used it? Or is it still relatively new?
Thank God Michigan doesn't get like that!
Originally Posted by Pharoh
Having said that, in Ottawa we had a couple of weeks that were colder than -40
Last edited by Scott Civic; Mar 22, 2006 at 04:35 PM. Reason: Automerged Doublepost
some of it does but yes, they do have the -40 stuff you can get. Having said that, in Ottawa we had a couple of weeks that were colder than -40
Xuhme
21
Aug 7, 2023 03:40 PM
cooldan1
Apr 23, 2015 10:49 AM
