Rear Defrost + Tint ?
Old Jan 16, 2006
Canadian Si's Avatar
Canadian Si will become famous soon enoughCanadian Si will become famous soon enough
Since we are starting to get some snow, just wondering if it's ok to use the rear defrost with the tint.
Old Jan 16, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
yes. tint is fine with the defrost. no problems.
Old Jan 16, 2006
dxray's Avatar
dxray is an unknown quantity at this point
I've had my tint for a couple of hard winters and had no problems using the defrost.
Old Jan 16, 2006
hondapower05's Avatar
hondapower05 is an unknown quantity at this point
It will actually help. When you first get the tint on, it is a good idea to run your defrost to remove the bubbles. And if you had the tint put on using water, it helps to get the water out. I had 2% metallic red put on with water and the defrost helped alot.
Old Jan 16, 2006
dxray's Avatar
I see you are from Nova Scotia, my home province, what part?
Old Jan 16, 2006
I'm from Cape Breton. You are in N.B. I usually go to the Fun Run in Shediac.
Old Jan 16, 2006
stripped02's Avatar
stripped02 is an unknown quantity at this point
If you run your deforst it will allow the tint to dry and connect faster. I have had 6% on my EX for about 4 months with the defrost running and I havent had a problem
Old Jan 17, 2006
digitaldemigod's Avatar
2001 Rallye Red EX
digitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of light
I worried about the tint too... my last car the tint was peeling and had lines that appeared "burned in" and I thought it was from the defroster. When I had my new ex tinted at the dealer they said it was fine to use it. Most times you don't see cars with rear defrost and ruined tint. On the other car it was probably a crappy tint job to begin with.
BigG422
Sep 9, 2015 10:59 PM
redcloud
Sep 7, 2015 01:45 PM
rainman15
Sep 6, 2015 11:10 AM
jpandjf
Aug 3, 2015 05:02 PM
Misfit2613
Jul 30, 2015 09:49 AM
